sea foam question.
Ok so after all my lean problem was traced back to the fuel system. I ran some of the fuel injuctor cleaner, it has new o2 sensors, I cleaned the iac and tb, now I am thinking I will seafoam it for good measure, and to clean out the rest of tthe fuel system. My question is after I dump a third of the can into the gas tank should I replace the fuel filter afterward, kinda like I will have to change the oil? Also am I missing anything as far as gettin the car clean?
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
My friend just added a can of seafoam to his car and hes changing the oil right now. as for replacing the gas i dont see how it can hurt in any way. good luck =)
3.9L V6
i prefer to run seafoam through the vaccum line...its the same method we use at the shop for injector cleanings....just use a straw, and a cup...take it slow and it'll be a good cleaning...
[SIGPIC][/SIGPIC] 6k HIDs - Rear Sway Bar - Mac Prochamber - Goodridge Gstop SS Lines - Lots of Visual Fun - Go Fast Mods (no point in buying...it's a v6) Want to see your car as art...ask me how |
So seafoam in the tank, and in the vaccuum line gets the same places? I also wanted to get the whole fuel system for good measure.
The soul stealing Ginger
well sea foam can go through the fuel lines and clean out anything along that way, but when it goes through the vacumn system, that pretty much covers the half the fuel tank missed,
Seafoam is a miracle worker. marvel mystery oil for the engine oil works freakin great as well.
![]() Cosmetic: Vent-visors, Pioneer Bluetooth Radio Deck, 17" Cobra Alloy Rims, HID 4500k 55watt setup, Chrome Headlamps 15% Tint, Red sway bar Performance: CAI,Mac-Longtubes, H-pipe, Flow 40s, NO CATS Diablo Tuner, Rear Sway bar |
November 08 ROTM
sea foam goes in the crankcase where you add oil, fuel tank, and vacuum system. easiest place to add it in the vacuum line is the big one that runs to the brake booster on the driver side. just get a funnel and have your e-brake set because your brakes wont work very good. gotta stay on the gas while you pour it in b/c you'll have a huge vacuum leak once you unplug the line from the booster.
id change the fuel filter while your at it. pretty easy to do with the fuel line puller tool. any auto parts store should have it for around $6-8
![]() ~Nitrous is like a Hot Girl with STD's, you know you wanna hit it, but your afraid of the consequences~ |
The George Forman of Keepers
I put mine in through the PCV valve. That way it gets to everything up top evenly. Word of caution though...if your car has alot of miles on it, your taking a risk.
As far as putting it in the gas tank, there wont be a need to change the fuel filter unless it needed it already. |
¡ʇsnq ɹo uʍop ǝpısdn
do the thirds system and then replace the fuel filter. that's for your best results, and seeing as you are worried about your fuel system, the most ideal route for you to take.
#9 | |
Glorious PC gaming master race
seafoam is fun
![]() i didnt change my fuel filter when i seafoamed but it wouldnt hurt to change it
![]() MILITARY CREW - USAF E-4
2001 Mustang GT
so i have a question maybe this sean foam is what i need???? so i have a 94 stang 105,k miles so not that bad but recently i noticce when im on a hill at a stop and i push the gas it feels like it bogs or wants to die and then sum times im driving and it feels like i have to push the pedal to get sum power lol i recently was turning at a signal on flat road and it all most died on me ... so some one HELP
2000 V6 Mustang
I had that problem..
I changed out my fuel pump and changed sparks and she was alive again..
2000 V6 Atlantic Blue GT Clone True Duals Flowmaster 40's originals custom "H" pipe Headers Eibach Drop Custom tuned w/SCT X3 and a lot more..... Saving for my NEW EDGE GT |
3.9L V6
sea foam might be too strong for something over 100k...i dunno for sure on that...you might need to use something along the lines of gum-out (weaksauce i know)...but the kind that goes through the vaccum lines, and then a bottle in the gas tank...thats what we use at work...
I don't think high mileage should be an issue, I've used some before, but it was only the third can my friend didn't wanna put in his oil. I ran it through the vaccuum line. The main thing I wanna hit is the fuel rails and make sure they are cleaned up.
01 True Blue v6
to slow to matter
I'm pretty sure seafoam is petroleum based and thus is safe on almost all years (unlike ones that are highly acidic). The thing that you gotta worry about though, is that if your car hasn't been maintained, using seafoam could remove the sediments that are keeping old seals/gaskets from leaking. But I don't think this is the case very often.
3.9L V6
sometimes clean is too clean...lol
btw..i didn't mean not to use it due to miles..i was talking about the ware on the engine from all those miles
[SIGPIC][/SIGPIC] 6k HIDs - Rear Sway Bar - Mac Prochamber - Goodridge Gstop SS Lines - Lots of Visual Fun - Go Fast Mods (no point in buying...it's a v6) Want to see your car as art...ask me how Last edited by 6ER THEN I 8ER!; April 8th, 2009 at 02:21 AM. |
Well so far so good...I did the thirds system and replaced the fuel filter, since I was almost outta gas anyway. Car feels amazing!
02 Mustang V6
13.605 @ 101.60
![]() iTrader: 6 reviews
What's the third system? Anyone have the link to a writeup?? Ya got me wanting to do it now!!
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
A third of the can goes in the gas tank, a third goes into the crank case, and you suck up a third with the vaccuum line.
Awhile ago i put a can in the fuel tank, half a can in the crank, and half through the PCV and worked perfectly. Im gonna do it again soon if i dont sell it first.
02 Mustang V6
13.605 @ 101.60
This thread made me go buy a can. Smoked like hell! Did the third system, can't notice much difference yet, maybe on the way to work tomorrow I'll feel it more but I def. have peace of mind knowing my baby's motor is squeaky clean inside! Thx for the tips!
Threads Similar to: sea foam question.
| sea foam | Divan | 5.0 Mustangs | 5 | September 28th, 2008 06:40 PM |
| sea foam ??????? | armymike63b | 99-04 | 13 | August 17th, 2008 02:03 PM |
| Sea Foam | Corey | 5.0 Mustangs | 5 | April 17th, 2008 03:32 AM |
| how to sea foam ?? | 96gtponyred | 96-98 | 5 | July 22nd, 2007 01:53 PM |
| Help after using sea foam... | 04GTAMPA | 99-04 | 4 | June 7th, 2007 11:16 PM |
