Car not starting
Yesterday there was a loose cable so I tightened it up and the car ran fine all day...This morning I go to start it and it makes this really rapid clicking sound but didnt turn. The wierd thing is the radio and all the elecronics worked fine...So I pop the hood and notice some corrosion. I cleaned the battery and cables with cleaner then reconnected it and the car started fine...Do you think corrosion was the problem or should I look for something else
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
your battery is low dont have enough amps to engage your solenoid fully to crank ur starter, charge the bat to replace it b4 u ruin your starter and solenoid. and what wire did u tighten did u create a dead short?
I tightened the part of the cable that connects to the battery terminal...yesterday the battery guage on the dash was a little higher than the half way mark
ok take ur cables off clean the terminals with a wire brush and the cables reattach and see if that helps if not its got to be ur battery get some one to boost yah and that will let u know for sure. had this problem with my war pig tempo lol turned out the cabled and terminals needed to be shined up
Good idea I hope its just clean up time
#6 | |
post back if it worked
Threads Similar to: Car not starting
| HELP! Car Not Starting!! | fastford3388 | 5.0 Mustangs | 1 | August 3rd, 2007 11:36 PM |
| starting | skid6 | 5.0 Mustangs | 2 | July 1st, 2007 12:49 AM |
| starting | skid6 | 5.0 Mustangs | 1 | June 27th, 2007 06:27 PM |
| starting | skid6 | 5.0 Mustangs | 1 | June 27th, 2007 06:26 PM |
| car not starting | ByPopularDemand | V6 Mustangs | 3 | April 7th, 2007 01:43 PM |
