Rough idle and take off?
i have a 94 mustang with about 200K miles. has worked great up until now, i recently replaced my muffler and rear exhaust pipe, drive shaft U joints, and spark plugs and wires, as well as the fuel filter. but now for some reason my car has a very rough idle and seems to want to cut off when i take off but when i get up to spend its fine. Any ideas? also occasionally if the car sits a while i get a little bit of white smoke from the exhaust, possibly a stuck intake valve?
November 08 ROTM
do the simple stuff first. check for vacuum leaks, clean the IAC and check the TPS. it could be a few different things.
![]() ~Nitrous is like a Hot Girl with STD's, you know you wanna hit it, but your afraid of the consequences~ |
ok dont mean to sound dumb or anything i know iac is the idle air control but whats TPS? and how would i check these im not used to mustang engines thats why i had to come here lol
November 08 ROTM
TPS is the throttle position sensor. sits on the side of the throttle body. unplug the sensor and check to see if the car runs differently without one or the other plugged in. you can try to clean the IAC with carb cleaner to make sure its not gummed up.
ok ill try that but would that explain the white smoke and strong gas odor?
Threads Similar to: Rough idle and take off?
| Rough Idle | killagt46_t-top | 99-04 | 5 | April 20th, 2010 12:22 PM |
| rough idle | graystang01 | V6 Mustangs | 4 | December 9th, 2008 12:22 PM |
| Rough Idle | AnFking6908 | V6 Mustangs | 6 | May 13th, 2008 10:38 AM |
| rough idle | Gsturbo88 | V6 Mustangs | 8 | March 22nd, 2008 09:36 PM |
| Rough Idle | MineralGreyGT | 99-04 | 19 | January 5th, 2008 10:51 PM |
