Cooling System Issue
So my car is overheating and I get no heat from the heater. Temp sensor is fine, tested and working. Replaced the water pump. Replaced the thermostat twice(had a nonworking one the first two times, finally got one that passed the boil test.) The upper radiator hose is hot and pressurized when the car is heated up, leading me to believe the water pump and thermostat are working just fine. I ran the car to red line on the heater gauge and the upper radiator hose was burning hot, yet the radiator was ice cold, along with the loser hose and the heater core hoses. Is it possible that I have a clog in the radiator AND the heater core lines, or if it's in the engine how am I getting hot fluid to the upper rad hose? I've been working at this for over a week now and I'm stumped. Anyone have any thoughts?
91 LX Notch
What year car? Check the lines going into the firewall for heat, at the heater core. Does the blower come on when you turn in on? Check your vac lines going to the back of the heater control panel. If they are not hooked up, you won't be able to select the heat.
http://www.sinisterstangs.com Last edited by 347Strokr; April 13th, 2009 at 07:27 PM. |
91 LX Notch
Scratch my response, no clue on this one.
http://www.sinisterstangs.com |
If the heater isn't working, the coolant level is probably low. You should bleed the cooling system by removing the bleeder bolt and adding coolant till it overflows. Also remove the radiator cap and add coolant to the radiator till it overflows.
If that doesn't help perhaps the radiator core is clogged. |
If the radiator is clogged, that shouldn't make a difference as far as the heater core is concerned, as it branches off the system before the radiator. I'd say the block is in the engine, but I'm getting hot coolant out the upper rad hose. My best guess at this point is there's a block in the heater hose, and the radiator, which would be highly unlucky. Am I understanding this right, or am I missing something easy?
My experience with the V6 Mustang is that if the heater doesn't work it is almost always because of low coolant. There can be enough to cool the engine but none in the heater hoses. I would bleed the cooling system first.
Next you might remove the radiator hoses and run water into the top of the radiator to see if it flows through. |
I popped open the bleeder valve and noticed white smoke coming out, looked at the exhaust and its the same thing. I checked the oil and it doesn't look like theres any coolant in it. Is it still possible that I have a cracked head gasket thats not allowing my coolant level to get high enough to pump to the heater core? And how would that affect no coolant flow in the radiator? Seems kind of unlikely to have a blown head gasket and a blocked radiator.
If there is white smoke (steam) coming out the exhaust that sounds like a head gasket. It won't necessarily get water in the oil. It can be confirmed by checking for exhaust gases in the coolant. I believe it is common with a bad head gasket for the coolant level to get low enough to not have the heater work.
Yea, its a bad head gasket, started her up and got the thick white smoke, and coolant in the oil, etc.
Threads Similar to: Cooling System Issue
| cooling system? | competition orange | 99-04 | 8 | March 26th, 2009 09:28 AM |
| Cooling Issue(s)... | Lefty | 96-98 | 7 | December 2nd, 2008 12:50 AM |
| Cooling Issue(s)... | Lefty | 99-04 | 11 | December 1st, 2008 01:41 PM |
| Bleeding the Cooling System | MUSTANG | V6 Mustangs | 3 | January 3rd, 2008 12:55 PM |
| 347 Cooling Issue | bgddy50 | 5.0 Mustangs | 35 | December 27th, 2007 11:34 AM |
