Idle at 2300 RPM
Old April 15th, 2009, 02:40 PM   #1
1995 Mustang V6
FireHawk is on a distinguished road
Idle at 2300 RPM
So I got a newer engine put in my '95 V6 (its an automatic) and I noticed that it idled little higher than normal, a little less than 1000 RPM in Park and Neutral. When it was put into gear though the RPMs went down to normal. My bad judgment told me it wouldn't get much worse plus it is just little higher than normal not really bad. So now around year and half later I am at around 2300 RPM sometimes when I put it in gear my car lunges (accelerates from high RPMS obviously). The RPMs though are normal once the car is in gear. I have been told it was a bad valve but I haven't really had it looked at since I have been busy in school. Well I am gonna fix it once I get back from college. Does anyone have any idea what it could be or the cost of it?
Oh and sorry for the long post...
1995 3.8 V6 Ford Mustang - Automatic Transmission (sadly)
For the record my username is not a reference to Pontiac...
Old April 15th, 2009, 02:44 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
egr valve, idle air control valve.. ect. both very cheap fixes.
Old April 15th, 2009, 02:47 PM   #3
1995 Mustang V6
Yeah I saw valves that weren't to bad at all in price but I know I will have to take it somewhere to get it fixed since I don't have a garage so I will get raped about the repair fees. I guess that means I will be out a car for a while...oh well first thing after I buy the GT is to fix the sixxer I guess...
Old April 15th, 2009, 02:51 PM   #4
HMUSN's Avatar
iTrader: 9 reviews
no need for a garage to fix that.. it takes like 5-10 minutes and a basic ratchet set.
just 2 bolts
Old April 15th, 2009, 02:57 PM   #5
1995 Mustang V6
Hmmm it appears I may do this myself then now just gotta find the ratchets when i get home thanks
Old April 15th, 2009, 03:03 PM   #6
HMUSN's Avatar
iTrader: 9 reviews
not a problem.. just be careful when taking it off so you do not tear the gasket behind it.
Old April 15th, 2009, 03:03 PM   #7
martinez23's Avatar
2001 Mustang GT
martinez23 is on a distinguished road
egr VALE
what does the egr vale look like and where is it
Old April 15th, 2009, 04:34 PM   #8
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to behold
iTrader: 8 reviews
Kenwood Head Unit $155
SCT Mass Air Flow Sensor $200
Old April 15th, 2009, 05:24 PM   #9
martinez23's Avatar
2001 Mustang GT
which one is the EGR vale ???
Old April 15th, 2009, 05:28 PM   #10
1997 Ford Mustang Base
Slow.
Elixir is on a distinguished road
Send a message via AIM to Elixir
I'm still tryin to figure out why my car idles around 850-1000 rpms...
Old April 15th, 2009, 05:30 PM   #11
martinez23's Avatar
2001 Mustang GT
clean the iac and throttle body that helped mine a lot buy sum cleaner from auto zone
Old April 15th, 2009, 05:34 PM   #12
MM's Official Lucifer
goren813's Avatar
'00 3.8L
+1 replacing usually isn't needed just a real good cleaning. And was that a serious question as to why your car idles where it should between 850 and 1000? That isn't out of the ordinary for these cars, clean up the valves, that may help, and there's a way to adjust the idle. If the cleaning doesn't help PM me and we'll discuss that.
Old April 15th, 2009, 05:45 PM   #13
Slow.
I don't know, this is my first v6. My first car was a Toyota Corolla, and it usually idles around 12-1500. Maybe it is just me being paranoid.
Old April 15th, 2009, 07:39 PM   #14
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 8 reviews
that might just be normal for that car...when its warming up it will run a bit higher than normal too
Threads Similar to: Idle at 2300 RPM
idle rpm w/ cams ajm 99-04 9 September 14th, 2008 12:15 PM
Idle RPM 89StAngerLX 5.0 Mustangs 5 October 3rd, 2007 02:18 PM
idle rpm 40thANVGT 99-04 13 May 2nd, 2007 02:50 AM
Erratic RPM in Idle mechwife General Tech 7 April 9th, 2007 02:10 AM
My idle is at 2000 rpm slingblade05 5.0 Mustangs 6 September 13th, 2006 04:04 PM
