Look Ma! My First Post!
1998 Mustang V6
split port swap
Well this is my first post, but have been reading for a while.
I have a 1998 and I was looking into doing the split port swap an was trying to make clear of what I need to make it happen. Thanks for the help |
#2 | |
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
*For the pre-99s only* Split Port Swap heres the full list (from plove71387): -99+ mustang v6 heads (including valves/springs) -99+ mustang v6 upper intake ** -99+ mustang EGR tube and valve -99+ Throttle Body -TPS sensor for TB (1-CX-1488 from Ford) if not already on TB -Throttle cable from 99+ mustang v6 -Modified fuel rail that has a universal fuel pressure regulator, and a return line. -Accelerator Bracket (F4SZ-9728-B) if not already included on upper intake -99+ mustang v6 coil pack and wires (your stock coil pack will work too) -99+ mustang intake tube, or any 99+ mustang CAI kit -99+ mustang cooling hoses (including the ones going to the heater core) and pipes. You can also make your own lines, by using plumbing elbows,hoses and clamps, and fab it up yourself. (Definately get these if you can.) -16 a.w.g automotive electrical wire -teflon tape, pipe sealant, RTV -99+ head bolts/studs -head gaskets (I recommend 99+ mustang gaskets) -99+ upper and lower intake manifold gaskets. -99+TB gasket |
Threads Similar to: split port swap
| windstar split port swap or port and polish | winnie51189 | V6 Mustangs | 22 | November 4th, 2008 05:04 PM |
| Split port swap | BDaily | V6 Mustangs | 6 | September 24th, 2008 10:08 AM |
| split port swap. | riddlee josh | V6 Mustangs | 12 | June 19th, 2008 02:15 AM |
| split port swap ? | theyanks904 | V6 Mustangs | 4 | March 27th, 2008 09:20 PM |
| split port swap | DeathScythe95 | V6 Mustangs | 3 | January 29th, 2007 01:13 AM |
