2004 Mustang Convertible
What part is this?
Cant post in the correct thread due to maintenance... so here it is. What is the name of the part of the engine directly below the intake manifold, the part that you bolt the intake to. V6, so it has 12 holes and 6 butterfly valves inside.
If you need a picture ill get one, but i am sure someone here knows exactly what i am talking about. Thanks!
![]() 2004 Convertible - SOLD 1999 Coupe - SOLD 1966 Coupe - SOLD 1987 TurboCoupe - Cut in prices! 1970 Coupe - Soon to be 140 Turbo! 1984 El Camino Conquista - moving truck 2011 Convertible V6 Base 2012 Coupe GT Premium 5.0 Baby! |
that's the split port, give you longer or shorter intake runners depending on what rpm your at i believe
Cervini's type iv hood, C-series bumper, Pypes mid-muffler exhaust, WMS CAI, 20" chrome wheels, Roush rear spoiler
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
Pictures seem to help more, but is this the part your talking about? Mine looks a little different that yours would but this hsould look something like yours if thats what your talking about,
![]() If so thats the lower intake manifold. |
+1! That is it thank you much. Now for the real question. Cleaning. Right now I do not have enough time to take it off before I need to drive the car again, so I am cleaning it in place. Any harm in spraying some carb/throttle cleaner into the valves to wipe off some of the crap in there? Would it be bad if some of it ran down farther through the engine?
¡ʇsnq ɹo uʍop ǝpısdn
why are you cleaning the inside of the lower intake??
i would suggest not letting anything fall down into the engine.
#6 | |
MM's Database Error
328/419 @ 4000 rpms
id take it off to clean it im sure it cant be that good to have that much liquid in that lower or wereever else it can get to.
I was cleaning because the valves we so gum'd up you could actually hear it while the car was idling. I didn't want to take it out because Its my daily driver and I only had 1 day off work. I got it cleaned out, too much of the cleaner got down in there, but I let it sit overnight before I put it back together. It didn't want to start but I held the starter on till it flushed some gas in there. Shoulda seen the cloud of white smoke. It engulfed my whole car for a couple minutes. Runs great now though, and the valves are no longer sticking. Thanks for the help.
What exactly do you mean you held the starter on. Because I took mine off to clean it and I sprayed the mounting surfaces on the heads with some carb cleaner before reinstalling the lower intake manifold. But when I put it back together it wouldn't start. It just cranked and cranked but never started and stayed on.
I held the key to the start position and gave it some gas until the cleaner burned off and was replaced by good fuel.
If that doesn't work you might re check your wiring to be sure you didn't forget something. Maybe the wire to the distributor
Funny you should mention the distributor because that was the first thing I checked. When mine cranks it sounds strong and will start but shut off immediately.
[8MINUS2]
we have distributors?!
So wait, it the engine starts and dies? Or will it not start at all?
IDK? but I figured he was talking about the ignition coil.
Threads Similar to: What part is this?
| where do i get this part | mantis3567 | 99-04 | 9 | February 22nd, 2008 01:37 PM |
| And some more part 2! | JAY'SRED02 | Pictures | 3 | October 7th, 2007 06:50 PM |
| what is this part? | lemon | 99-04 | 15 | March 21st, 2007 09:01 PM |
