2003 mustang GT
![]() iTrader: 1 reviews
what is the ticking noise in my 2000 3.8
it makes a ticking noise everytime i hit the gas mostly when its half way around 2-3000rpm
any ideas i just got my ls n car so im tryin to fix it up so any mods please let me now currently got viper strips 20" devinos bbk intake and underglows |
exhaust leak?
Yup...cracked exhaust manifold. Most likely on the passenger side.
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
The George Forman of Keepers
Im guessing....valve train noise, if its not exhaust.
2004 Mustang Convertible
I also have a ticking noise, in my 2004 vert. It happens constantly, but it loudest when i start the car. I had orginally thought it was bad valve lifters, but I checked and they all seem to work fine.
Right about when the car started ticking, I sprayed my engine bay down with a hose while it was still hot. Could this have cracked the exhaust manifold, and if so, would it cause a ticking sound?
![]() 2004 Convertible - SOLD 1999 Coupe - SOLD 1966 Coupe - SOLD 1987 TurboCoupe - Cut in prices! 1970 Coupe - Soon to be 140 Turbo! 1984 El Camino Conquista - moving truck 2011 Convertible V6 Base 2012 Coupe GT Premium 5.0 Baby! |
MM's Official Lucifer
+1 On that exhaust leak, pass. side right before first cat closest to engine. If not a deflection plate as JA said, you can fit a hose into the A/C port where it drips and run it down past the exhaust and everything... $30ish to reweld that up at a shop if you take the exhaust off and bring it to them.
"Fast she goes...in the city of Overdose" ![]() |
#8 | |
#9 | |
Yep...if it was hot when the water hit it. |
I cant see any visible cracks, anyone know of a way to find out for sure if its my exhaust without tearing too much apart?
2004 V6 Coupe
It does not have to be cracked. I have dual exhaust with headers, and I had this same ticking problem. I did not have a crack anywhere, instead it was just a couple slightly loose bolts that connect the headers to the pipe. It happened everytime the car would change seasons because of the heating and cooling expanding and contracting the metal. I just tightened the bolts and put some high temp thread lock on them and I was fine.
Wax on, Wax off
![]() ![]() ![]() Sorry... i will go away now
It's the underglow kit. Your mustang is trying to shake it off.
99 Cherokee sport/87 5.0
not tested
lol. shake that rice off!
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander |
An exhaust shop can use a stethoscope to locate the leak. Commonly it's at the flange at the bottom of the manifold where it connects to the pipe. If the manifold is off the car you can also look for carbon at the joints. The stock manifolds were pressed together with only tack welds. If you have an exhaust shop weld all the way around it should fix it. Also as someone else mentioned put anti seize on the studs and on the flared pipe end, get the exhaust aligned, and torque the nuts to specs.
1999 Mustang V6
![]() iTrader: 3 reviews
I have he ticking noise too. It only happens sometimes when I accelerate from a stop at a little less than half throttle. I'm not too concerned about it tho, because it doesn't seem to bother anything and it doesn't have any problems at full throttle, or any other time really.
2000 Mustang
Could just be a bomb?
![]() Detailing Crew Member North Carolina Modded Mustangs #5 |
#19 | ||
01 True Blue v6
to slow to matter
I found my cracked exhaust manifold during an oil change...its not hard to spot if you are looking for it
Threads Similar to: what is the ticking noise in my 2000 3.8
| a ticking noise | 87gtmustang | 5.0 Mustangs | 20 | February 7th, 2009 02:43 PM |
| a ticking noise | 87gtmustang | 5.0 Mustangs | 2 | February 4th, 2009 04:27 PM |
| Ticking Noise? | 99Rumblebee | V6 Mustangs | 3 | September 27th, 2008 01:08 AM |
| ticking noise | 1 SNAKE 3 | V6 Mustangs | 19 | February 14th, 2008 07:03 PM |
| ticking noise | kreil45 | 5.0 Mustangs | 2 | April 23rd, 2007 03:11 PM |
