Discussing Header Removal in the V6 Mustangs Forum. Guys: I was mounting my JBA headers on my 2005 V6 Mustand and have not ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Header RemovalI was mounting my JBA headers on my 2005 V6 Mustand and have not been able to remove the stock exhaust maniforld studs from the head. I tried to take them out with and E7 torx socket, the male end just broke. I tried to double nut them and the studs will not move. The temperature is about 36 degrees in my garage. I also tried a bit of heat to the head and vise grips to the stud, still no movement. Any ideas...No I will not take it to the Ford Dealer.... |
#2 | |
1995 BMW 325i
get a haynes manual
http://img.photobucket.com/albums/v3...5/cpc1copy.jpg
1999 Ford Mustang V6
14.79 @ 92.15
why remove the studs? your headers wont bolt up in the stock location? not sure for the 05+, but when i bolted mac long tubes on my 99, i just needed the new manifold gaskets and 6 nuts...
MM Ninja / Site Moderator
2001 Mustang 232/CBR600
14+@Slow
i wouldn't risk removing the studs if you snap that off in the block its going to be a huge HUGE pain in the ass to drill and tap the broken stud out.
![]() Modded Autos Join today, All makes all models ̿̿ ̿ ̿̿'̿'\̵͇̿̿\=(•̪●)=/̵͇̿̿/'̿'̿ ̿̿ |
Studs need to be removed to take off the stock exhaust manifold. I took the wifes blow dryer and heated the exhaust ports for a few hours....yes it worked.
When you have an aluminum head and 4140 case hard studs, the cold sucks/shrinks the aluminum around the stud by as much as .015. The trick is to heat the aluminum head around the stud without heating the stud to much. Thanks for the advice:-) |
#6 | |
14.79 @ 92.15
#7 | |
Moderator
8.876@80.013 1/8th
Why do they need to be removed? I don't even see how clearance would be the issue, and thats the only issue I could think of aside from the headers being stuck...umm so why did you have to remove them?
Blue Mustang Society click it
Guys:
The studs have to be removed because they interfer witht the exhaust tubes on the headers and do not allow you to seat the header flange. Guess you all got lucky...
#9 | ||
never heard such a thing deepcave...
i never f'd with the exhuast tubes when i did my bros 98
#10 | |
14.79 @ 92.15
Well now you have heard of it....give JBA a call and ask them about their tube bends. And then ask them about the interference of the stock exhaust manifold studs on the 4.0L V6 with their headers.
Quickest way to remove the studs is with a little heat, a sharp blow on the top of the stud and a Lisle stud remover. For any of you Redneck Mechanics out there, just cut the interfering studs off a bit. Then grind the burr and recut the threads with a die. |
Threads Similar to: Header Removal
| EGR Removal??? Anyone know about these things and Header ins | Slowbra_12 | 96-98 | 4 | October 25th, 2007 06:54 PM |
| transmision removal | stangergt1 | 5.0 Mustangs | 2 | April 5th, 2007 12:30 PM |
| Help: TB and EGR removal | nolife | 5.0 Mustangs | 4 | March 18th, 2007 10:24 PM |
| Scratch Removal | Coltdog | 2005+ | 1 | March 16th, 2007 12:40 AM |
| Manifold removal and header install, help plz | MySallyMI | Exhaust | 5 | January 9th, 2007 12:49 AM |
