check engine light
So all I did was replace my fuel filter and now the engine light is on, but there are no leaks I am kinda stumped atm...took it to advanced auto parts there computer said it was a fuel air meter. Any ideas would be appreciated..
hmm...I have no idea. I replaced the fuel filter on mine when I had it and had no problems whatsoever. Have you looked at it again since you put it in to make sure everything is in order?
MM's Database Error
did u put it in backwards?
2003 Mustang GT Vortech
![]() iTrader: 1 reviews
i would unplug the battery after checking to see the fuel filter installed in right the right direction and leave the battery off for 10 min then restart and see if it help's could been casued by the fuel psi sensor reading a low psi since you replaced the filter.
Ford Certified Tech Land Rover Certified Tech Ase Certified Tech Honda/ Acura Certified Tech AllData Automotive Information Specialist 03 Mustang GT Vortech V3 Intercooled 407/415 to the wheels BOOOOSSSTTTTTT
I installed it in the right direction Ill try unplugging the battery because that follows my something got tripped and the computer is being stubborn theory lol.
#6 | |
May not appy to a 3.8 Essex fuel system though, the 4.6 fuel rail had a pressure regulator the size of a quarter, ours are bigger than that and may not be as senitive to fouling..problems with pressure regulation can cause the car to run too rich or too lean..that will give you a warning light.
[SIGPIC] Total budget blaster, Im under $3,000 still! Rebuilt motor, CAI, Dual disconnected Thrush Weldeds on "Dumps", wheels from a New Edge and Spoiler off of ..."something", I think a New Edge GT? Sweet ride, short money!
Lol well the light went of by itself magically. I still checked somethings out and it was all good. Then this mourning bam light doesnt stay on. Also it could of been the fact the computer was confused because I know the previous owner never changed the fuel filter or really took that much care to the car so yea im going through and changing anything that might need changing odometer is sitting at 65k now ive owned since 41k so besides oil changes I really didnt bother with anything else, but now that im dumping mods into it I thought it would be a good idea to change things out.
that's a great strategy. The more things you replace that are broken, the less things you have to worry about
3.9L V6
seafoam
[SIGPIC][/SIGPIC] 6k HIDs - Rear Sway Bar - Mac Prochamber - Goodridge Gstop SS Lines - Lots of Visual Fun - Go Fast Mods (no point in buying...it's a v6) Want to see your car as art...ask me how |
Lol nah im not gonna seafoam cause I honestly dont know how to do it
Oh also whats a good way to check if the exhaust is leaking cause at times it just doesnt sound right...
seafoam will help find exhaust leak's. it's easy to do just search here and you will find out how to do it.
#12 | |
The George Forman of Keepers
Call around and see who can "smoke it". The put a smoke machine that will introduce smoke in through the tail pipe under pressure. Wherever there are leaks, it comes out. It works real well and is usually pretty cheap. Much more accurate that Seafoam if you dont want to seafoam. |
2003 V6 Mustang
14.2 @ 96
Haha nothing to worry about, had the same thing happened to me. I pulled the code and it was basically low fuel preasure. All it was, is your sensors detected the low fuel preasure when you draining your fuel lines.
Disconnecting the neg on the battery and hitting the brakes a few times will clear the CEL. There is nothing wrong. |
Threads Similar to: check engine light
| Check Engine light still on?!?! | trueblue02GT | 99-04 | 9 | December 31st, 2008 04:22 PM |
| check engine light | MisterFast3 | V6 Mustangs | 5 | August 12th, 2008 12:52 AM |
| need help with check engine light | 02MiNeRaLgRaYGT | 99-04 | 3 | November 30th, 2007 05:05 PM |
| Check engine light | Dellbinder | Audio/Video | 4 | October 29th, 2007 12:40 PM |
| Check engine light? | 95stangergt5.o | 5.0 Mustangs | 5 | April 28th, 2007 02:00 PM |
