car running weird
Old May 4th, 2009, 10:06 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
car running weird
ok so i got a 02 v6 5spd with k&n cai, udp, dual exhaust, sct xcal 3 if any of these make a difference. well i recently cleaned my k&n filter and idk if i used to much oil. i mean if i did wut would it really harm? jc. i noticed now that my car when i go to shift makes a weird noise that i never really noticed it almost sounds like a little blow off valve. would that be the filter cuz i used to much oil? and if so should i just re clean it and oil it and make sure to use less oil? and if i did use too much oil will it really harm anything to bad so ik how urgent it is to re clean. thanks
UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors
Great Automotive How To's http://tooldesk.com/blog/
Old May 4th, 2009, 10:07 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
when it makes this sound are you shifting at a high rmp? like racing?
Old May 4th, 2009, 10:56 PM   #3
white03v6's Avatar
2003 V6 Mustang
Too long@Too slow
white03v6 is just really nicewhite03v6 is just really nicewhite03v6 is just really nicewhite03v6 is just really nice
^+1
my bbk sounds a little like a bov when i take the rpms high enough
Old May 5th, 2009, 09:25 PM   #4
Codeman's Avatar
idk i mean it kinda does. it is towards the higher end i mean i have had the k&n for about a yr and a half. i didnt notice anything but it could be i just didnt hear it. it kinda happnes most if i like punch the gas quick and let off then shift so it might be how it makes the noise at high rpms. oh and on the other part if i did over oil it would it cause great harm to my engine like the recharge kit said? im kinda new to this whole k&n thing. thanks
Old May 6th, 2009, 06:39 PM   #5
2003 V6 Mustang
14.2 @ 96
ewells2420 is infamous around these partsewells2420 is infamous around these partsewells2420 is infamous around these parts
If it only happens when you shift, its probably not your CAI.
Old May 6th, 2009, 10:54 PM   #6
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
is there a turbo set up on your car that you didnt know about?
www.moddedmustangs.com
Old May 6th, 2009, 11:33 PM   #7
mooses is on a distinguished road
If you over oil the filter, there is a chance it could get the MAF sensor dirty and your car would run like ass.
Old May 7th, 2009, 12:23 AM   #8
97fordsixer's Avatar
97 single port w/bolt ons
n/a
97fordsixer will become famous soon enough
take apart what you just did when oiling and recheck and reassemble. it didn't happen just for coincidence. you probably didn't put together 100% or maybe knocked something else loose in the process. its worth a try.
bolt ons for now..... split port swap very soon....
Old May 7th, 2009, 11:33 AM   #9
MM's Official Lucifer
goren813's Avatar
'00 3.8L
If it isn't affecting performance then I doubt you're really hurting much, as said just check to see if any oil is carrying up the intake to the MAF and such. CAI's will make a noise as described when the butterfly valve in throttle body closes and air is circulated back thru the intake piping. Mine does this towards higher RPM's and isn't really noticeable when shifting around 2k. Maybe the filter needed a good cleaning and the flow is a lil more now so more air=more sound? I dunno... but doesn't sound like it's broken.
Old May 7th, 2009, 10:29 PM   #10
white03v6's Avatar
2003 V6 Mustang
Too long@Too slow
my car only makes that noise when i shift and its definitely the cai.
and i was kind of thinking what goren was thinking...maybe having more air coming in because of the cleaner filter, you also have more air rushing out when the throttle body closes, so the noise is louder and more noticeable?
and to codeman ...the higher i take the rpms, the louder the noise is, and like mooses said, if you overoiled, you would be able to feel a difference. i think its no big deal since you havent said that your car is running terrible, its just making a noise.
Old May 7th, 2009, 11:51 PM   #11
Codeman's Avatar
ok well i was jc. and im glad that nothing bad can happen i didnt really fig anythin could i was just makin sure. and i will check the maf and clean it anyways just cuz i doubt it has ever been cleaned. and ya it might be just cuz it is different cuz it has been awhile since i had a clean filter lol. but thanks for the help.
Old May 7th, 2009, 11:54 PM   #12
2003 V6 Mustang
14.2 @ 96
huh ..... wonder why, im trying to figure out how shifting would affect the CAI. Then again I dont have a manual so there might be something involved with the gas pedal or whatnot that im not aware of when shifting.
Old May 8th, 2009, 12:00 AM   #13
white03v6's Avatar
2003 V6 Mustang
Too long@Too slow
i think goren explained it, but im not sure.
but if he didnt...when i take my foot off the gas to shift, the throttle body closes, and so all the air still in the intake wants to escape so it passes back through the intake tube, and thats when the noise is made.
edit-ya goren explained it
Old May 8th, 2009, 12:03 AM   #14
white03v6's Avatar
2003 V6 Mustang
Too long@Too slow
yep, if something was going wrong because of an over-oiled filter, youd feel it. and checking/cleaning the maf would be a good idea just in case, although i doubt theres anything wrong. and your welcome!
Old May 8th, 2009, 12:13 AM   #15
1999 Mustang Gt
greengoblin is on a distinguished road
clean filter sucks more air and will make a sound similar to a bov. try just quickly reving the engine from idle and see if you hear it. most likely the reason you are hearing it at shift points is because you are shifting at higher rpms and then getting right back into the gas quickly as you let out the clutch and that is why you are hearing it. o and over oiling the filter will not harm your engine but can dirty up your maf wire, i would not worry about the over oil if the car begins to hesitate or driveability goes down slightly clean the maf with maf cleaner do not use brake cleaner or anything else along those lines.
Old May 8th, 2009, 12:39 AM   #16
2003 V6 Mustang
14.2 @ 96
ok yeah, that does makes sense.
Old May 8th, 2009, 09:51 AM   #17
goren813's Avatar
'00 3.8L
Thanks for the back - up white.
Old May 8th, 2009, 02:04 PM   #18
Codeman's Avatar
ok so im pretty sure it is just the filter. i just got used to it bein dirty so it wasnt as loud. cuz thinkin back to when i got it i loved how it sounded like my car was turboed. so im sure it is just the air rushin back out when the throttle butterfly is closed. that makes sense.
Old May 8th, 2009, 06:16 PM   #19
white03v6's Avatar
2003 V6 Mustang
Too long@Too slow
yep, anytime
Old May 8th, 2009, 06:16 PM   #20
white03v6's Avatar
2003 V6 Mustang
Too long@Too slow
cool, glad we got it figured out!
(i love the sound too haha)
Threads Similar to: car running weird
Weird problems with car (electrical) Avengence 2005 - 2010 10 January 6th, 2009 08:04 PM
car running weird DeMello The Clubhouse 55 July 5th, 2008 03:44 AM
car acting weird shadow5403 V6 Mustangs 6 May 15th, 2008 12:57 PM
running weird?? mustangrebuilder 2005 - 2010 18 April 23rd, 2008 02:54 PM
!!! (Weird Car) mustang1072 All Other Vehicles 7 January 30th, 2007 09:10 PM
