Water Leak on passenger side of 06
I was wondering if anyone has any ideas on what could be wrong...
My 06 V6 randomly started letting in water about a month ago...i took it to the dealership and the replaced what they said was a broken cowell (sp)...yesterday as i was driving throgh OK on my long journey home, I noticed about an 3/4 inches of standing water in the passenger side of the car...possible leak in the seal of the windshield?? I really don't know... |
2000 Mustang
Were you running the a/c?
![]() Detailing Crew Member North Carolina Modded Mustangs #5 |
no...it is definitely rain water. I read on another thread that it might be due to a faulty weatherstripping or something...apparently there is a recall...if only the dealership would have informed me of this.. I've also read that it could be a backed-up water drain or something like that under the hood but i couldn't find it based on the info from another thread.
1994 Ford Mustang GT
you have that much standing water and you cant see where its coming from? checking for wet spots under the dash or on top you should be able to see a water spot in the right light if its running down your dash or something
www.moddedmustangs.com |
2007 Mustang GT
Thank you everyone. After two trips to the dealership and $800 lost, I finally found the spot where the water was entering and was able to buy a $5 bottle of sealant and fix it in ten minutes.
Admanistrator
its a common problem with the cowl. leaves and debris block up the drainage, and when it rains, the water backs up and comes in under the dash. you can take the cowl off and clean out the leaves. it sucks. it happened to me also
#8 | |
Thanks |
Threads Similar to: Water Leak on passenger side of 06
| Water coming from under passenger side dash??? | Fox2102 | 2005 - 2010 V6 | 11 | May 6th, 2009 08:38 PM |
| Slight water leak out of the water neck | Novanutcase | 99-04 | 4 | December 23rd, 2008 09:37 PM |
| passenger side thing? | zack065 | 2005 - 2010 | 3 | August 22nd, 2008 06:25 PM |
| passenger side exhaust | forensicsteve | 2005 - 2010 | 2 | June 11th, 2008 03:03 PM |
| Focus Leaking Water Into Passenger Floor | OTreborO | All Other Vehicles | 4 | November 9th, 2006 12:15 PM |
