Xcal 3 user Options
Just got My xcal3 (x3000) today, thought it would be fun to show the user options in order. you can pick custom that have been loaded for you or you can change these settings
Fuel Octane *Premium *91 *87 Fuel Economy *Normal *Fuel Economy Fuel Injectors *Stock *24lbs *30lbs MAF *stock *80mm light MAF Rear O2's *on *off EGR *on *off Traction Control *on *off Spark 0-2000rpm *4 deg / 2deg/ 0deg/ -2 deg/ -4deg/ -6deg/ -8deg/ -10deg/ -12deg/ -14deg spark2000-4000rpm *4 deg to -8 deg spark 4000-8000rpm *2deg to -8 deg WOT AIr/Fuel *14%richer *12%richer *10%richer *8%richer *6%richer *4%richer *2 %richer *0%richer *2%leaner *4%leaner *6%leaner AXLE Ratio *stock up to 4.56 Tire revs/mile *stock *500revs/mile up to 900revs/mile Speed limit * off down to 60mph Rev Limit *5000rpm- 7000rpm Idle speed Drv *440rpm-890rpm Idle speed Neu *520-1320 Low speed Fan *170deg F - 230 Deg F High speed Fan *180deg F - 240deg F Thats all the options that appear on my Xcal 3 (x3000) when i click on pre programmed tunes. |
Anyone has any sugestions on what settings to put everything at? or does the customs tunes from SCT dealers have alot more paramters they can change. and doing it myself would be worthless?
idk good question i just got mine about a month ago too and i was curious on the things to change. ik the only thing i changed on mine besides different octanes and driving conditions was the idle speed i dropped like 50 i think i thought it sounded a little cooler and i changed the rev limit in neutral cuz i got a manual i changed it to 2700 so i could hold the gas to the floor with the clutch in and not worry and it made a pretty big difference in acceleration at least my little light to light races. lol but ya idk wut else to adjust to so i guess a little help for the both of us would be nice lol.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
You changed it to 2700??? my option doesnt let me go that high. and im confussed by what you mean you can hold the gas to the floor and not worry? want to explain that more? lol
i also have a stick shift |
SG
2005 Mustang GT
2001 Mustang V6
You can hold the gas to the floor and it will not go past 2700 RPM. That way you can be rest assured knowing that you're not going to spin your tires off the line.
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok. 05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel |
#6 | |
KB'd GT
Dude, you are not supposed to EVER hold the gas to the floor while its bouncing off the limiter!! Use just enough gas to let it hit the limiter then go wot when you dump the clutch. sometimes some cars have trouble exiting the neutral limiter so check it at part throttle first. |
2003 V6 Mustang
14.2 @ 96
hah I never even used that option, I use my VMP custom tune then change the settings hes unlocked. Most of that stuff you dont need to touch. Unless you want to turn off TC which a lot of people do like myself.
TRICK TUNERS...
Do you have any suggestions when i go back to that dealer i went to. any parameters you recommend to tell him to change while im there. ? maybe some that you know that he might not . maybe narrow it down to the most benificial ones?? |
2003 V6 Mustang
14.2 @ 96
Yeah you are really better off by getting a canned email tune from someone like VMPtuning.com or maybe even that trick tuners guy, never dealt with them so I dont know.
They will adjust all the settings so they improve performance on your engine to what mods you have. |
ok i c on the whole neutral rev limiter. i didnt know that i always thought that was why the drag cars popped on the line a lot is cuz the limiter but i supposed that is still hard on them. thanks for telling me before i screwed something major up.
2003 V6 Mustang
14.2 @ 96
If by "popped on the line" you mean doing wheelies it has nothing to do with what RPMs they launch at ..... well it does but not the way you are thinking about. They can do that because A. They have dragg radial which are sticky as hell and B. They have the HP and TQ to do it lol.
#12 | |
KB'd GT
yeah, they pop because of the limiter, but its best to use just enough throttle to keep it on the limiter, and floor it just before you are going to dump the clutch. |
i meant by popped how they sit there hold in the car at a constant rpm and it just sounds like the neutral rev limiter they r using.
Threads Similar to: Xcal 3 user Options
| New user from Utah. | Iconoclast107 | New Members Introductions | 41 | May 1st, 2009 04:15 PM |
| User Groups | Margarita Girl | Feedback Forum | 3 | February 16th, 2009 11:56 PM |
