Questions
Anyone have instruction on how to remove power steering pump/install a new one?
And can you install mil eliminators on both the front o2's and rear o2's to turn all four off? |
#2 | |
[8MINUS2]
1st question: I'm sure there is some manual at a local auto store you can get for that. 2nd question: no
01 True Blue v6
to slow to matter
You HAVE to have you first pair of o2 sensors in place for your car to be able to run the right fuel/air mixture.
Considering I still have a check engine light for the front O2's and nothing is wrong with my car, would that mean the front O2's arent reading right. Should they be moved up further, if so then how far? I have a full exhaust system mac Lt's, hpip, cback, without cats.
then the 02's are either bad, or were put in wrong when the exhaust was installed. Are both banks running lean?
01 True Blue v6
to slow to matter
You also might have a leak before the o2 sensors. Make sure your bolts are tightened.
#7 | |
A shop fixed the leaks that were created by the dmg. Though if there was a leak it would be extremely tiny between the front o2 to the head gaskets. I don't hear any leaks. |
2003 mustang v6
232rwhp@7psi
i have heard before that the 02 sensors can be too far back on the mac longtubes and therefore not read correctly. could this be the problem?
V0rTech'D
Threads Similar to: Questions
| 2 questions? | dmachine22 | All Other Vehicles | 2 | March 9th, 2009 09:09 PM |
| Questions | zinc02GT | The Clubhouse | 12 | September 19th, 2008 11:38 PM |
| Un questions.. | homebrewed | The Clubhouse | 8 | June 11th, 2008 05:10 PM |
| I have some more questions | 92stang0802 | 2.3 Mustangs | 7 | June 16th, 2007 11:17 PM |
| just a few questions | glassJAw | V6 Mustangs | 8 | January 18th, 2007 02:53 PM |
