Discussing Rear End in the V6 Mustangs Forum. Just found out my v6 has a 8.8 rear end with 3.27 gears. ...
Old January 25th, 2007, 09:30 PM   #1
Rear End
Just found out my v6 has a 8.8 rear end with 3.27 gears. Mine ring and pinion gear broke can anyone help
Old January 25th, 2007, 09:55 PM   #2
Resident MM Ricer
GreenFaleen's Avatar
2006 Scion tC
13.9@103/8.9@81
yeah you got the 8.8 buy some 4.10's and go have fun.
Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS
Thanks To My Sponsors:
Strup Performance
Old January 25th, 2007, 09:58 PM   #3
Shop Says i should get a new diff what do u think. I thought my rear was stock
Old January 25th, 2007, 10:07 PM   #4
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
why you need a new diff? unless you like blew something important up in there I'd say they are just trying to get money out of you. also when you burned out did you have both wheels spinning? cause if not you do have the 7.5 rear end but if you have an 8.8 you've got a good rear end get some 4.10s and have fun
Strup Performance
Old January 25th, 2007, 10:25 PM   #5
report says ford 8.8 rear diff/ non limited slip 3:26 ratio rear diff spider gears and cross pin are broken. the pin broke and the retianing bold and slid from diff. the carrier bore is wallowed out.. the pin contActed the pinion gear and damaged it. Does this mean anyting to u
Old January 25th, 2007, 10:26 PM   #6
Air Embolism Assassin
Cricket's Avatar
8.876@80.013 1/8th
means when the stuff broke it damaged the stuff around it. Try to find a rear end from a GT of your year, and throw it in there. It will be the 8.8" and then just buy some gears you want to throw in it. How did you break it?
Have we officially crossed the line now? I just got Douche chills. Thanks a lot JP.
I gave zippee douche chills
Blue Mustang Society
click it
Old January 25th, 2007, 10:28 PM   #7
can i just get a new rear diff already have 8.8
Old January 25th, 2007, 10:30 PM   #8
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
yeah what did you do to bust up your spider gears?
Strup Performance
Old January 25th, 2007, 10:30 PM   #9
quick question what rear do i have on a stock 99 convertable?
Originally Posted by Luvdmustang
Originally Posted by ThePonyExpress
do they make a spoiler delete kit or would i have to buy a trunk
that would basically be like neutering your mustang
Old January 25th, 2007, 10:31 PM   #10
i was just driving no racing
Old January 25th, 2007, 10:31 PM   #11
prob 7.5 with 3.27
Old January 25th, 2007, 10:37 PM   #12
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
I think 99's add had 3.55.
but yeah I think you need a new rear end.
Strup Performance
Old January 25th, 2007, 11:48 PM   #13
SP00LIN V6
2000 Mustang V6
unknown @390
the v6 doesnt have 3.55s machs do though
and a stock v6 doesnt have a 7.5
if you do then throw some 3.73s or 4.10s if the t-lok is bad get a 31spline t-lok
437rwhp and 402rwtq through a V6 on a stock bottom end
Old January 26th, 2007, 12:09 AM   #14
scubasteve041186's Avatar
2004 mustang 40th annv.
can you get a 31 spline t-lok for a 7.5?
Old January 26th, 2007, 12:24 AM   #15
SP00LIN V6
2000 Mustang V6
unknown @390
i dont think so, i think biggest you can fit is a 28
Old January 26th, 2007, 09:03 PM   #16
found one 900 bones
Old January 27th, 2007, 01:16 AM   #17
The spider gears in the 8.8 are only marginaly stronger than their 7.5 counterparts. And still the weakest link. If you want a stout rear, now is the time to do it. Auburn or True Trac dif and gears. Or you could spend a little more and 31 spline Auburn or True Trac dif, gears, girdle, 31 spline Moser axles and you're ready for drag slicks.
http://www.cdrvideo.com/mustang/avatar1-copy.jpg
332/365@10.2psi
Old January 27th, 2007, 11:03 AM   #18
Mustang RacR94's Avatar
03 mach 1
13.2@109
rear
so basically i think thats the rears they put in GTs not sure , i have the same rear my brother did a total rear swap when he had the car just get some new gears 4.10s but if u do highway driving and are worried about gas shoot for the 3.73
2003 Mach 1, 5 speed
MM MACH 1 CREW
"Dont worry ive locked horns with this fucker before"- TasteMyThunder
www.myspace.com/mustangracr94
Old January 27th, 2007, 11:26 AM   #19
Check this link out for spec.
http://web.tampabay.rr.com/theflock/...doorplate.html
Might anwser some question on stock v6 95 and up on spec.
Old January 27th, 2007, 07:16 PM   #20
Thanks guys
Threads Similar to: Rear End
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 13 October 20th, 2008 03:29 PM
Rear End D-Brow V6 Mustangs 16 April 18th, 2007 12:54 AM
What rear end? ken5_0 5.0 Mustangs 13 March 20th, 2007 02:01 AM
Rear End Pharoh V6 Mustangs 9 February 16th, 2007 10:56 AM
Rear Rotors and Rear Axle rondaw3g0410 99-04 1 September 6th, 2006 11:00 PM
