P1413
So this is turning into probably the biggest nightmare of all times. Im an unemployed mechanic and i have many of my scan tool and tools left. So a Brand New AIR PUMP or some of you would call it a smog pump was replaced none of the hoses were bad, Cleared the code 1 hour later popped back up I cant get the car inspected because of this problem and when i clear the code the monitors clear off so i have to drive it around again before i take it for inspection then by then the code pops up again, now on an older post someone said the Vacuum solenoid but what the hell is that? They must mean the solenoid on top of the egr valve i guess, Anyways, 300 dollars later nothing fixed
i feel like running this car into a wall. I hate inspection states
If you checked everything then it could be the pcm damaged, bad solid relay,
Threads Similar to: P1413
| Trouble Code P1413 | Mrs_Mustang | V6 Mustangs | 36 | December 1st, 2010 06:46 PM |
