Bad Sounds
I have a 2002 mustang. when i make turns the car makes a cracking sound. it sounds like it is coming from the driver side rear wheel. i am hoping that it is nothin major but if anyone has any ideas on what it could be that would be greatly appreciated. Thank you.
First welcome to modded mustangs the problem could be your u joints does it get louder at turns? more info please...
2003 Mach 1 Procharged 500rwhp club
yea when i drive normal it usually doesnt make any noise. it does it bad when i make a sharp left turn and sometimes when i make a right turn.
Then that's your problem buddy!...
awesome
1994 Ford Mustang GT
yeah it might not be too bad on a 2002 mustang, rusty old pick ups are my favor ones to replace them on! lol usually ends up with me angry and a tourch in hand
www.moddedmustangs.com |
sounds like cv axle.
you better get that checked and/or fixed asap! |
I know my friends 300zx made some loud noises when the motor mounts broke
Go Pokes! MM Cobra Club #33 VERT CREW #02 |
1999 Ford Mustang V6
when does it make the "loud cracking sound" when driving or coming to a stop?
might want to take the wheel of and look around, check the control arm bushings, caliper, lugs, wheel, rotor, pads.
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
I Hate Convertibles...
before you go and replace your u-joints check them. see if there is any play in the joints. ive had u-joints go out and it doesnt sound like your havin the same issues i had
It makes that sound all the time. while im driving normal over bumps or making turns. making a left hand turn is the worse though. how much do the u-joints cost and are they easy to swap out yourself or do u have to go to a mechanic to get that done.
The u joints are not expensive, maybe $20 per joint of which there are two.
If you take the drive shaft out any machine shop can replace them, or it can be done at home with some snap ring pliers or needle nose pliers and a few sockets and a hammer. For the procedure look in a Chilton's or shop manual or you can find videos on youtube that describe it. |
i jacked my car up today and it isnt my u joints i just got massive back lash on my driveshaft.
Threads Similar to: Bad Sounds
| Sounds like.. | whtpny | The Clubhouse | 4 | June 14th, 2008 03:55 AM |
| this sounds like so many here*L* | vfast | The Clubhouse | 4 | April 20th, 2008 09:12 PM |
| You think its sounds best? | Trent-04v6 | General Tech | 38 | February 27th, 2008 05:52 PM |
| Which Sounds Better? | Mlx50man | 5.0 Mustangs | 27 | December 20th, 2007 11:16 PM |
