M112
Ok so what does it take to install this? how about a parts list? Does anyone have one?
[8MINUS2]
Basic hand tools,
parts list is on v6power.net it would be easier just to buy the entire kit though.
Safud: MM's Resident Hadji
2003-2004 Cobra M112 Supercharger
2003-2004 Cobra plenum 2003-2004 Cobra throttle body 2003-2004 Cobra 39lb injectors Cobra 90MM MAF With MAF Sensor 2003-2004 Cobra boost bypass 2003-2004 Cobra supercharger pulley 2003-2004 Cobra throttle and cruise control bracket 2003-2004 Cobra air intake tube 2003-2004 Cobra TPS sensor 2003-2004 Cobra M112 supercharger gasket- RTV sealant works best 2003-2004 Cobra plenum gasket 2003-2004 Cobra throttle body gasket 2003-2004 Cobra fuel injector O-rings 1999-2004 Mustang V6 upper intake gasket M112 intake adaptor PCV delete 2003-2004 EGR delete IAT Sensor and Wiring CNC MAF flange 310lph fuel pump (98-04 cars) NGK TR7IX spark plugs Gatorback belt #4061182 or 6PK3002(metric part number) Air Filter With Filter Box M112 EGR delete 12 bolts for adapter to V6 lower intake 12 washers for intake bolts 10 bolts for M112 to adapter 4 bolts for the plenum to the M112 4 bolts for the throttle body to the plenum 4 bolts for the MAF to CNC flange 2 bolts for IAC delete to plenum 2 bolts for IAC relocation 2 bolts for IAT relocation to M112 2 bolts for Cobra throttle cable bracket 2 clamps for air filter Custom made pieces: Tuning EGR delete Coli pack bracket Radiator hose IAC relocation IAC block off plate Idler pulley setup IAT relocation plate IAT gasket Shave off intercooler lip Longer wiring for IAT relocation ^ for the basic swap
where can i buy the entire kit?
PM mysteed over on the 3.8mustang forums. I believe he sells the whole kit for $2800. It comes with everything but tune and gauges
Wait I'm lost lol what kind of swap is this??
An Eaton M112. Its the supercharger off the 03-04 Cobra's
v Mine ![]()
And it is 2800 for the kit for a v6
Yeah, something around there. I haven't followed it too closely so I'm not sure if he's changed the price lately.
edit: look at the post below this one. Last edited by mooses; June 10th, 2009 at 12:07 AM. |
2003 V6 Mustang
Too long@Too slow
i think he might have it at 3000 now i talked to him awhile ago, and thats what he said, but im not sure what its at now
muneris pro ego
a cowl hood will be needed as well
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
2003 V6 Mustang
Too long@Too slow
^unfortunately yes...
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
If you can find one to cover it lol .. and i belive his kit is 2800 plus shipping. Good luck with making a kit, its alot cheaper if you have the know how. I got mine all done for 1500-1700 at most not including a tune. Search around SVTPerformance.com for some good deals on parts.
2003 mustang v6
232rwhp@7psi
i believe you can get this to fit under a gt hood scoop...
V0rTech'D
#16 | |
2003 V6 Mustang
Too long@Too slow
Mysteed told me you need the extended hood scoop...Intercooled Complete Supercharger Kit for the '99-04 Mustang GT - Click for more info....its close to the bottom of that page
#18 | |
2003 mustang v6
232rwhp@7psi
EDIT: that page doesn't work for me..
V0rTech'D
#19 | |
328/419 @ 4000 rpms
Nice then, He must have a nice small adaptor plate now .. i know in the begining his was about the same size as SSMS.
you can get alot of good prices over there .. those guys just looking to get rid of their stuff .. Shaved mine all by myself using a grinder and being very careful. |
Threads Similar to: M112
| m112 on a 2V ? | SleeperStang88 | 99-04 | 12 | June 9th, 2009 01:59 PM |
| m112 on v6 | SleeperStang88 | 4V / SVT | 3 | April 29th, 2009 02:30 PM |
| M112 on a 2V! Yes you Can!!!! | ohcat68 | 99-04 | 14 | May 2nd, 2008 10:16 AM |
| Eaton M112 | rob3980 | V6 Mustangs | 8 | April 22nd, 2008 01:36 AM |
| m112 | mmvi | V6 Mustangs | 34 | March 5th, 2007 04:38 PM |
