Continuing saga of a rough running engine
Old January 28th, 2007, 09:45 PM   #1
mickchu is on a distinguished road
I had a 95 mustang with a blow engine. I got the block refurbished and with 2 refurbished heads had a professional to install the engine. For eight months the car was running like a dream giving 24 mpg. Two weeks ago the engine started to run rough. The check engine light came on giving a code P0305. Gas fume cam though the air vents. I changed plugs wires but there was not any improvemnts. The check codes did change to P0500. I noticed that on spark plug # 2 was wet. I change the injector but no effect. I change the cam senser and the coil pack but no improvements. With the rough runnimg engine I am lucky to get 10 mpg.
Any sugestion.
Old January 28th, 2007, 09:48 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
full over diagnostics check man.
NCMM #9
Old January 28th, 2007, 09:49 PM   #3
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
rough... sorry buddy i'm not too sure obviously gas is leaking or flooding somewhere though cause it's not just dissapearing lol. i'm gona go check what the code means though and get back to you.
Old January 28th, 2007, 09:53 PM   #4
k so
p0305 is misfiring
p0550 is a speed sensor error...
yeah dude no clue.... some one screwed up something to go from a mis fire to a speed sensor. best you got is a full diagnositics test and a haynes manual and try to trouble shoot from there. maybe someone else will be able to help out.
Threads Similar to: Continuing saga of a rough running engine
Need help with rough running V-6 wildhorse V6 Mustangs 19 October 11th, 2007 01:43 AM
Running Rough 92mustanglx 5.0 Mustangs 5 April 6th, 2007 07:44 PM
97 GT Running Rough? rainbowmustang 96-98 5 March 21st, 2007 05:00 PM
rough running engine mickchu V6 Mustangs 9 January 25th, 2007 12:28 AM
'99 Mustang Running Very Rough With Little Horsepower thefastdraw V6 Mustangs 6 October 5th, 2006 06:02 PM
