problem after sea foaming >:[
Old June 17th, 2009, 04:20 PM   #1
horizontalkev is on a distinguished road
I put 1/3 into vacuum line and 1/3 into gas tank and followed the instructions perfectly..
I start up all fine but when I drive its sluggish, really really sluggish, I drove it down a 45 mph road and eventually I got to the speed limit butstill reallly reallly sluggish, what's wrong?
I checked to make sure the hoses are connected properly and alls fine.
Old June 17th, 2009, 05:30 PM   #2
03 Mach 1 & 02 GT
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
Seafoaming My Mustang - Ford Mustang Forums
This should help just remember that you need to get rid of the oil and gas, did you put it seafoam on your tank when it was full of fuel? sorry for not giving you the link before, actually I gave this link to another member in here... Give it wot throttle again you have to change your oil, spark plugs and you had to have a little a amount of fuel. If the white smoke is already gone do this^ if you car had a little bit of white smoke then that means that your car wasnt that bad and when the're a lot of smoke coming that means that you had a lot of carbon in there..
2003 Mach 1 Procharged 500rwhp club
Old June 17th, 2009, 07:52 PM   #3
Thanks man, although I never put it into the oil..
The problem cleared up after letting it sit a while..
I had no change in performance what-so-ever so I took it to auto parts to pull the code.. or should I say codes..
I have 3 codes my cars slapping me with right now.
1. Misfire detected in cylinder # 6 *ignition system fault-spark plug, ignition wires, coil
2. EGR system fault (exaust gas recirculation) *failed EGR valve
3. Ignition coil primary circuit condition -- coil # 3 *ignition coil defective
Codes pulled 30 min of driving after sea foaming, no change in performance.
What do these 3 codes represent, and have in common?
Any easy DIY fix for any of these problems?
**I have a video of the sea foaming job on my car ill post shortly**
Old June 17th, 2009, 07:58 PM   #4
03 Mach 1 & 02 GT
I think that all that will be resolved with new spark plugs, coil, and wires..
Also i'm not sure if this should happen or someone gave you a bad advise..
So you just put it on the pvc hose? and not on the gas tank?
Old June 17th, 2009, 08:09 PM   #5
Maybe I'm gonna get the code pulled again else where..
I put 1/3 into pvc hose and 1/3 into gas tank (half a quarter left)
Can I dip the EGR valve in some kind of cleaner?
Old June 17th, 2009, 08:19 PM   #6
03 Mach 1 & 02 GT
yes the electronic cleaner will work, I believe autozone have them.. or any part store.
Old June 17th, 2009, 08:22 PM   #7
Electronic cleaner?
The guy I talked to at the auto parts I went to said the EGR valve is not cleanable because the "fine" parts of it are clogged with carbon.. what's that about?
Old June 17th, 2009, 08:27 PM   #8
03 Mach 1 & 02 GT
ask him about carb cleaner cuz the egr valve cost like 70-80 or take it out and you will see what to clean plus dont forget to buy the gasket, the egr looks like a little hat or plate and I think theres 2 or 3 bolts holding it.
Old June 17th, 2009, 08:32 PM   #9
03 Mach 1 & 02 GT
http://www.carpartswholesale.com/ima...t/egrvalve.jpg
That's the egr valve...
Old June 17th, 2009, 08:35 PM   #10
So if I completely clean the egr it will be just as good as a new one?
And new gasket, no doubt.
I meant to ask about 2 things I noticed while sea foaming..
1. Same color smoke that was coming from the exaust was also coming from the back, bottom part of the engine, I believe where the headers are(what ever the pipes are called connecting to back cylinders *3 and 6*)
2. Before I was gonna kill the engine a big poooofffffff of smoke from the tube that was sucking the SF. with a low 'pop' immediately killing the engine. What's that about?
Old June 17th, 2009, 08:40 PM   #11
03 Mach 1 & 02 GT
I don't know about that but the egr usually fail when there's a lot of carbon and that's the purpose of the seafoam so I think after changing what i told you it might solve everything. ( not sure ) Yesterday I was watching a video on youtube about this so you may want to check some of them and see...
Old June 17th, 2009, 08:48 PM   #12
So the sea foam will clear the carbon out of the egr?
I'm just having so much problems with the car..
1 more thing, when I start sometimes all of my guage needles go all the way over and back why?
Lol sorry about the questions, get them all out while someones helping :]
Old June 17th, 2009, 08:54 PM   #13
03 Mach 1 & 02 GT
Lol I also have that problem but I guess is something related to electric things cuz I have a short or a false ground cuz my battery use to die everyday and alternator was good and batt...
So it stop doing it dunno why and after a month it started to drain my battery, I have a sound system and yes when my battery is low all the needles move. So I think is the car's computer gettting reset since theres low charge on the battery ( not sure do ) I haven't done any research about that..
Old June 17th, 2009, 09:07 PM   #14
Actually that makes sense, I killed my battery completely a few days ago listening to music with the car off, and yes I also have a sound system
But my battery died quickly (10mins of playing).. and also I notice when the engines off all the light dim in the interior when I press either brake / lights and everytime the speaker "beats(bass)".. car never did that..
This is what I'm gonna do, tonight charge the batter full..
Tomorrow clean off spark plugs/ clean EGR/ inspect ignition coil
Old June 17th, 2009, 09:13 PM   #15
03 Mach 1 & 02 GT
I got tired of taking the car to electric shops since they told I have no short and when I was going back home the dome light stayed on??? all the time so I removed the interior light fuse.
With my sound system almost full volume I kill my battery in 30min and I don't have a huge one just basics 2 12's. Oh my headlights light also dim on each boom so that's normal.
Clean spark plugs? replace them that's what you have to do after seafoaming your car..
Old June 17th, 2009, 09:37 PM   #16
Lol ok, I listen to house/ techno/ electro and as you know the beat hits every second so if you can imagine my batter gets killed quickly..
And I will change them, can I get the stock plugs from walmart or only from paets store?
Old June 17th, 2009, 09:41 PM   #17
03 Mach 1 & 02 GT
Yes, dunno about walmart, Get an optima battery they take way longer to die.. theres red and yellow top dunno if wal mart has them but autozone does...
Old June 17th, 2009, 10:27 PM   #18
Ok, ill look into that more.
Took the stang out, it runs slightly better.. but CEL lights still on..
But I'm gonna do as I said still.
Old June 18th, 2009, 03:51 AM   #19
2003 Mustang V6
Arsenical is on a distinguished road
I thought that is due to the alternator instead of the battery, do you have a capacitor? In my last car my lights dimmed like that too but was due to the heavy loud i was putting on my alternator, when I hooked up a 2farad capacitor into my setup I no longer had that problem.
My gauges jump around too on startup, Isn't that a test the car's computer runs on startup to test the gauges? I assumed so because I can select the gauge test through the mileage display and it will make the gauges reset like that every time.
2003 Mustang V6
Shoppinglist: HID kit, 4.10 gears, t-lok, windstar, udp, cam, exhaust
Old June 18th, 2009, 03:55 AM   #20
1999 cobra
99blkcobra is on a distinguished road
Send a message via Yahoo to 99blkcobra
dont wanna get that stuff where its not suppost to go
1999 Mustang Cobra (rebuilding, someday...)
1996 civic dd
[/SIZE]
MM Cobra Club #3
Threads Similar to: problem after sea foaming >:[
sea foam Divan 5.0 Mustangs 5 September 28th, 2008 05:40 PM
sea foam ??????? armymike63b 99-04 13 August 17th, 2008 01:03 PM
best sea story ever deedub97GT The Clubhouse 2 May 19th, 2008 03:01 PM
Sea foam flattusmaximus78 94-95 3 May 15th, 2008 07:22 AM
Sea Foam Corey 5.0 Mustangs 5 April 17th, 2008 02:32 AM
