check engine light on
Old January 29th, 2007, 05:07 PM   #1
Look Ma! My First Post!
Yoursuperman22 is on a distinguished road
if you get a diagnostic test run on it what are all the problems that can show up and what are the most common?
Old January 29th, 2007, 05:09 PM   #2
2005 Ford Mustang v6
29.99@too slow
ScreaminYellow05 is on a distinguished road
Send a message via AIM to ScreaminYellow05
from what i hear, alot of times it's just your o2 sensor. what year stang is it?
Old January 29th, 2007, 05:11 PM   #3
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
there are hundreds of diagnostic codes and none are most common i suppose you have the possibility of having any of them some show them selves mor often then others but usually when u start to mod your car forinstance using an off road h or x pipe will make your engine throw an o2 sensor code unless u get it modified not to.
Old January 29th, 2007, 05:35 PM   #4
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
get a code from autozone they will check for you and post it we can tell you if it is a 99-00 it is probably your rear o2 sensor.
NCMM #9
Old January 29th, 2007, 05:36 PM   #5
Juggalo_X's Avatar
14+@Slow
i didnt think rear o2's threw a code just triggered the light and generic obd2 wont grab it i thought.
Old January 29th, 2007, 05:38 PM   #6
1995 BMW 325i
232stang is on a distinguished road
Send a message via AIM to 232stang
after alot of miles, it will usually throw a lean code or 02 sensor code. at least thats my experience with fords. my mustang, my dads f-150, and another truck.
Originally Posted by Cesar2cool
lol i use my car for speed
Old January 29th, 2007, 05:39 PM   #7
Juggalo_X's Avatar
14+@Slow
ive experienced alot of egr low or no flow codes ended up being a 2 dollar part i think its called pvc valve or pcv valve.
Old January 29th, 2007, 05:39 PM   #8
29.99@too slow
any ford i've ever own or my buddy worked on he disconnected the o2 sensor
so it wouldnt throw the check engine light unless theres a real problem.
Old January 29th, 2007, 05:46 PM   #9
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah it want I was just saying thats more than likly the problem especially with no code. The x-cals disable them now in every tune you get.
NCMM #9
Threads Similar to: check engine light on
check engine light 02ATIstang 99-04 24 May 22nd, 2007 05:03 PM
Check Engine Light brose1388 2005 - 2010 4 April 28th, 2007 03:26 PM
95 3.8L check engine light nikbait V6 Mustangs 3 February 24th, 2007 02:57 PM
Check engine light ByPopularDemand V6 Mustangs 18 January 9th, 2007 01:50 PM
Check Engine Light? GreenFaleen V6 Mustangs 13 November 20th, 2006 02:26 AM
