Throttlebodie Lag!
So I installed a bbk 65mm throttlebodie. I took it out for a test drive and it would not shift very well. Then it seemed like in second gear it would not excellerate barely at all when I had the pedal to the floor. Any ideas of wat could be wrong?
[8MINUS2]
Best I can tell you is to double check everything and make sure its alright.
That is an expensive paper weight you bought buy the way
Ideas:
Did you connected the maf sensor or/and tps back? ( the maf causes a lag ) If that was done correctly then I would remove the intake tubing again then pull the throttle with your hand and make sure is opening and closing with minimal force...
2003 Mach 1 Procharged 500rwhp club
Everything was installed correctly. I believe it is the tps. Do new throttle bodies come with plastic inserts that go into where the tps bolts in? Cause if so then I didnt get one with my throttle bodie. Could that be a probable cause of the problem. The reason why I ask is because I compared the stock throttle bodie tps hole to the new one and the new one was much bigger.
#5 | |
It points to be that cuz the tps based on the position of the throttle, the computer will decide how rich the fuel mixture will be at any open throttle point....
Or you may need to adjust the tps or buy a new one, try this..
You will need a Phillips screwdriver, a pin, and a voltmeter that can read low voltages accurately. Here is the procedure: 1) Loosen the two screws holding on the TPS, (The screws can be very stubborn, so make sure you have a good quality screw driver that fits snug and has a long handle for lots of torque, or you might strip the heads) just enough to able to swivel the TPS with force. 2) Pierce the "GREEN" wire with the pin and hook the positive (+) lead from the voltmeter to it. 3) Ground the negative (-) lead from the voltmeter. Use a good ground, like the engine or other grounded metal source. 4) Turn your ignition key to the run position, but do not start the vehicle 5) Rotate the TPS until you achieve .98 to .99 Volts (For stock or slightly modified engines). 6) Tighten the screws on the TPS and recheck.
MM's Official Lucifer
Read posts. But yes, check/adjust tps as said.
Ok will do
Nothing is wirking and there is no way to adjust the tps using the volt meter. Any other suggestions? Im about to return the damn thing.
MM's Database Error
prolly ur best option anyway and spend ur money on something better. tb's arent worth the money without doing it all out with the p/p upper and lower intake, etc.
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
1994 Ford Mustang GT
yeah id take it back if possible
www.moddedmustangs.com |
I agree with johnson.
Ok will try to return it.
Threads Similar to: Throttlebodie Lag!
| Site Lag | Drick | The Clubhouse | 18 | December 11th, 2007 11:02 PM |
| Throttle Lag | superpede1 | V6 Mustangs | 21 | August 30th, 2007 03:31 AM |
| lag | stanged out | V6 Mustangs | 11 | May 13th, 2007 04:05 PM |
| WOT LAG!!!!!! | terminal velocity | Modular Mustangs | 5 | May 5th, 2007 02:33 AM |
| LAg when I press the gas | nHuman | 96-98 | 7 | December 25th, 2006 02:41 PM |
