1999 mustang v6
projector headlights vs regular headlights
hey guys i want to purchase a new set of headlights but arent sure to get projectors or regular ones. I do like the style of projectors tho. Whats the difference between projector headlights and regular ones? and which are better with HIDs?
The only comparison that stands out in my mind is that projectors look nicer, but don't put out as much light.
However, if you decide go with regular headlights, we have them in stock on our website. But either way, I wish you luck in finding what works best for you. 1999 Ford Mustang Headlight Driver Left Side 1999 Ford Mustang Headlight Passenger Right Side |
1999 Ford Mustang V6
I like the regular look with clear corners... but to each their own.
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Moderator
2003 Grand Cherokee
Projectors are better for HIDs. Reflector housings are NOT designed for HIDs and result in terrible glare to oncoming drivers.
The type of housing you choose has NOTHING to do with the amount of light output. The amount of light output is determined by the type of bulb you're using. The housing is just to focus the light and make it usable for seeing (focus it into a beam).
Authorized Vendor
![]() Join Date: Sep 2008
It isn't just a question of projector vs reflector; you also need to take into account how the entire system was designed. Put a bright HID bulb in a reflector designed for a halogen light, and you'll get a terrible beam pattern. Lots of light, but not necessarily where you want it, and you may lose your high beams (or some of the systems are more like losing your low beams as far as oncoming traffic is concerned). OTOH, there are also a lot of second rate projector lamps out there.
My advice if you want HIDs is to get a set of OEM HID projectors off of something like a late model Acura or other car with easily transplanted HID projectors, and shoehorn them into your stock housing. That way you end up with a system of lights and housing that are designed to work together, meet all legal requirements as long as you align them right, and get you more light with a good beam pattern. |
#6 | |
Moderator
2003 Grand Cherokee
2002 Mustang
Projectors=Belong on Rice
Smoked Lens on a Mustang=Omg
"Dream as if you'll live forever,Live as if you'll die today" ![]() http://www.moddedmustangs.com/forums...-member-10050/ http://www.moddedmustangs.com/forums...-car-club.html |
#8 | |
Threads Similar to: projector headlights vs regular headlights
| projector headlight headlights or not? | panther19762001 | V6 Mustangs | 27 | January 12th, 2009 12:35 PM |
| Anyone have projector headlights like this? | 86ttops | 5.0 Mustangs | 9 | January 11th, 2008 06:49 PM |
| Projector Headlights | graystang01 | V6 Mustangs | 24 | November 29th, 2007 03:43 PM |
| Projector Headlights came loose | Murderjetz | General Tech | 0 | September 28th, 2007 10:38 PM |
