What're some basic things to do to prolong my engines life?
It's got 175k+ on it now and I'm really startin' to feel it. What sort of basic things can I do to get my car running healthy again?
#2 | ||
175 holy shit:
oil fluid brake fluid trans fluid spark plugs hoses
#3 | ||
not to be a dick but id save up some cash and pull a engine off a wreked stang 97 or 98 id keep ur block because if they ever go into the classic car mode where they are selling like the 67s you can have all numbers matching and rebuild the engine
ahhh. your car is just starting to break in. just regular maintenance, fluids, plugs and stuff and you'll be ok. my car had just broke into the 100k mark and it feels like it hasn't even reached its peak yet.
ok so how much did your parents pay for your car? |
Also, I got a puff of smoke coming up out of the window sill when I rolled down my window today, wtf was that about?
#6 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
forge your internals and you got your self a new toy.
Could someone explain forged internals? I never understood that one
MM's Resident Ricer
2006 Scion tC
13.001@113
simply it is your internals only instead of being different pieces put together they are forged out of one piece meaning they are stonger since it is one item instead of 3 or 4
Where would I go to check those out?
MM's Resident Ricer
2006 Scion tC
13.001@113
tom morana racing has them I think chris or cricket will know better than me.
muneris pro ego
www.supersixmotorsports.com has the forged internals as well... you will find that SSMS is highly recommended here
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
95% of the wear on an engine happens in the high rpm and speeds. stay below 65 to keep it at a minimum. use a manual. Manual's last longer its a fact. Buy the base model of whatever. The more gadgets and stuff the more shop time your looking at if something goes out. Basically a 5-speed stang with regular oil changes, driven normally, with no electric windows and locks will run till the wheels fall off.
#15 | |
Yet another example of the mis-informed giving bad info on the web.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
MM's Resident Ricer
2006 Scion tC
13.001@113
ok then please explain that is how they were explained to me.
#17 | ||
All too often...too many people rely on poor information that their peers have given them. It would be a better world if people were not so lazy and just do some basic research and find their own answers to common questions.
MM's Resident Ricer
2006 Scion tC
13.001@113
that was explained to me by a guy at a speed shop and what you posted was just the ways of forming the materials. Forging uses one solid piece casting uses multiple things put together at different stages of the process I just dumbed down my explanation a lot.
#19 | |
FYI...A cast piston is made from one piece. A cast rod is made from one piece. And a cast crank is also made from one piece. What your saying makes no sense and is wrong. Either you mis-interrupted your buddie at the speed shop or he has no clue.
MM's Resident Ricer
2006 Scion tC
13.001@113
they are one piece yes but when you cast if you have to drop the molten metal in in stages so it is compounded together making certain points weak since they are where the connection happens. While forging is shaped all at one time.
Threads Similar to: What're some basic things to do to prolong my engines life?
| Basic 99-01 Cobra Tech FAQ | 2000Si | 99-04 | 5 | January 25th, 2012 05:37 PM |
| Basic help needed. | hooligan | 2.3 Mustangs | 10 | November 2nd, 2007 05:24 PM |
| Got a basic design for my tattoo. 68' GT500KR | ckthecerealkiller | The Clubhouse | 13 | January 12th, 2007 02:07 PM |
| Basic Information..... | FunNquick | 5.0 Mustangs | 2 | August 17th, 2006 11:08 AM |
