#21 |
#22 |
Hopefully he does a good job on it. Don't want to get you nervous, but maybe he gets used gears really cheap so he didn't mind adding them in. Do you have the tuner to correct the speedometer?
#23 | |
You know what they say... If it sounds too good to be true, it probably is.
#24 | |
#25 |
Yeah I hope so. Someone suggested I write up a contract for him to sign specifying the exact labor I wish for him to do. It sounds like a good idea in theory however I'm not sure how to go about that exactly.
#26 |
It would be safer to do something like that, but I'm not sure I'd really bother with it. As long as you've drilled it into him that you want 3.73s, and he writes it on your work order receipt, I think you'll be fine. I'd suggest jacking the car up after you get it back, and spin the tires and count driveshaft revolutions to make sure you actually got the right ratio installed.
#27 |
2003 Mustang V6
Ive been thinking of doing motive 4.10s and FRPP T-lok too, but how reliable are the FRPP T-loks? and doesn't the speedometer need some kind of adjustment after the mod?
![]() 2003 Mustang V6 Shoppinglist: HID kit, 4.10 gears, t-lok, windstar, udp, cam, exhaust |
#28 |
You will need a tuner to correct your spedo^ I would go with the Ford racing t-lok imo......
#29 |
You can break a tlok under stock power if you launch hard enough. I'm assuming since you are considering 4.10s, that you have an auto. If this is the case, I seriously doubt you'll break a tlok anytime soon unless you have some serious power upgrades on the way. You'll need a tuner to adjust the speedometer so it is correct.
#30 | |
2003 Mustang V6
#31 |
I've heard of t-loks broken on n/a cars, however from what I understand it's fairly rare.
Threads Similar to: FRPP T-Lok and Motive 3.73's
| What is the NON motive frpp 4.10 #? | navyman8903 | 2005 - 2010 | 10 | March 13th, 2009 02:52 AM |
| Gears - FRPP vs Motive - Just a Little Clear Up | DiZzyBonne | Modular Mustangs | 3 | June 12th, 2008 09:18 PM |
| Gears: frpp 3.73 or Motive 3.90? | eLLuSioNiST | 2005 - 2010 | 9 | May 20th, 2008 10:23 PM |
| Motive VS. FRPP | sstang | 99-04 | 10 | October 25th, 2007 03:38 AM |
| Motive Gears Vs. FRPP | themav46 | V6 Mustangs | 6 | January 9th, 2007 10:58 AM |
