HID flicker then shutoff problem...help!!!
Old June 24th, 2009, 01:25 PM   #1
The Black Car's Avatar
2003 Mustang 3.8L v6 Conv
Probably a year @ Pushing
The Black Car is on a distinguished road
Send a message via AIM to The Black Car
so i just bought an hid kit (xentec to be specific) with harness ballasts and bulbs. i wired everything up the way the manual specified to do it and one of the lights flickers for like 1 or 2 seconds then shuts off (i had my mom stand in front of the car and watch the light flicker, or else it would be too fast and i wouldnt be able to see it). one thing i noticed is that when it flickers and shuts off, and then i turn the lights off, and turn them back on, that one light doesnt flicker, it just doesnt go on. so i went and popped the bulb out and i noticed the base that the bulb sits on was a little slanted, so i pushed the base, without touching the bulb itself, and i heard it click back into place (almost like what happens when a circut breaker has to be reset in your house). then i went to go and turn the light back on and it flashed again for 1-2 seconds and shut off. so ive concluded maybe everytime i flip on the lights the "breaker" on the bulb flips and it has to be put back into place. i figured the bulb is not bad, nor is the ballast as i have tried the working bulb in both ballasts, and all is well with that one. i have been reading about people installing capacitors, so i bought a capacitor from radio shack (a 470uf, part no. 272-1030) but i dont know how to connect it to the ballast if it even is supposed to connect to it (should i splice it in?). someone please help, im driving around at night with only 1 working bulb and foglights as auxilliary.
Old June 24th, 2009, 01:33 PM   #2
98stangv6's Avatar
1998 Mustang V6 SLOW
17.13@80.85
98stangv6 will become famous soon enough
Send a message via AIM to 98stangv6 Send a message via Yahoo to 98stangv6
Do you turn your lights on before you start your car?
JAKE'S PIITB CREW MEMBER#4
Old June 24th, 2009, 01:38 PM   #3
03 Mustang V6
bloodusmc is on a distinguished road
Did you check to make sure its grounded good?
also check if the bulb is good.
take it out and look at it.
Semper Fi!
Old June 24th, 2009, 01:56 PM   #4
grounded good. bulb is good ive looked at it to the point where i was able to figure out that clicky "breaker" think i mentioned above. *turns lights on with car on*. still no luck though trying this capacitor, i just dont know where to put it. i also heard you can put it into the relay, but the only thing that i think might be the relay is something called a hi/lo controller box. it seems like a relay but idk? any other suggestions?
Old June 24th, 2009, 02:03 PM   #5
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
I would start by switching bulbs to balasts. Basically, you currently have bulb A connected to balast A and bulb B connected to balast B. Try connecting bulb A to balast B and bulb B to balast A. See if the problem stays with the bulb or balast.
Old June 24th, 2009, 02:14 PM   #6
^ ya i tried that too, thanks though, lol, balasts are good and the other bulb works on both ballasts. that one faulty bulb i have been talking about is the culprit, but because of that clicking "breaker" thing, i have reason to believe that the bulb may be good and i just need a capacitor?? can anyone confirm this?
Old June 24th, 2009, 04:33 PM   #7
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to behold
iTrader: 8 reviews
the way i see it is that you shouldnt need anything extra if you got a full kit. i would check to make sure the connection to the ballast is good on that side. where did you ground it on the car? u might need to make sure there isnt a lot of paint where u grounded it and make sure it is on there tight, a loose ground can cause it and eventually screw up ur ballast
Kenwood Head Unit $155
SCT Mass Air Flow Sensor $200
Old June 24th, 2009, 04:38 PM   #8
jim.munoz's Avatar
2000 V6
jim.munoz is on a distinguished road
Your bulb shouldnt be doing the clicking/breaker thing. replace the bulb.
Silver Vehicle Club Member #4
http://www.moddedmustangs.com/forums/signaturepics/sigpic9615_8.gif
Old June 24th, 2009, 06:07 PM   #9
2003 mustang v6
xBIGxWHITEx is on a distinguished road
Send a message via AIM to xBIGxWHITEx Send a message via MSN to xBIGxWHITEx
one thing i noticed was the resistor for stock lights was different then the one needed for the HIDs. check the owners manual for the diagram of the fuses find the stock one and then check the instructions to see what fuse is recommended for the HIDs. if they are the same then i guess thats not the problem.
Old June 24th, 2009, 06:19 PM   #10
98stangv6's Avatar
17.13@80.85
On your ballast there are two connections, one connection is to your headlight wiring harness and the other connects to your bulb. Unplug the one that goes to your bulb and flip it to the other side and plug it back in, its a little snug but it will fit. Mine also flickered when i JUST bought the kit, and after i did that its worked fine ever since..
Old June 24th, 2009, 06:33 PM   #11
Moderator
2003 Grand Cherokee
Do NOT change any fuses in your stock wiring. Fuses are designed to protect the wiring and are not dependent on the load. Changing the fuse size will increase the risk of starting a fire. The stock wiring fuse is not the problem.
Old June 25th, 2009, 08:18 PM   #12
newmustang is on a distinguished road
is grounded good?
Old June 27th, 2009, 03:50 AM   #13
ya ground is ok, the manual said to ground it to the green screw in front of the battery, so its nice and tight. but i really thought about it and came to a final conclusion, that the bulb is faulty (did the whole switcheroo thing with the bulbs, and one of them works on both sides no matter what, and the other doesn't work on either side). the guy i bought it from is sending me a new bulb as a replacement and hopefully that should work. i got a lot of responses from everyone, and i would like you all to know that i really appreciate all your help, you guys are one of the few honest ones i can turn to in time of need so thanks.
Threads Similar to: HID flicker then shutoff problem...help!!!
hid skuzzy Visual 3 April 11th, 2009 01:36 AM
head lights flicker on my 89 White 89 5.0 Mustangs 19 August 25th, 2008 03:43 PM
HID Wiring Problem RC04SVT Audio/Video 1 June 30th, 2008 09:13 AM
Hid and Foglight Problem chromestang01 V6 Mustangs 9 June 10th, 2008 10:16 PM
Problem with installing Hella HID kit on 2004 V6 xzibit88 Audio/Video 6 April 20th, 2007 05:55 PM
