M112 Questions
Ok so im starting to gather parts for the m112 kit and im coming across a few parts where idk where to get them or idk wtf they are.
Parts idk where to get 03-04 cobra tps sensor 03-04 cobra throttle and cruise control bracket Parts idk what they are 03-04 cobra boost bypass PCV Delete- Cant i just use breather valves?? IAT Sensor- Dont have one on my car now do i still need one?? cnc maf flange |
#2 | |
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
VMP tuning sells taht cnc flange, iat senor and pcv delete i belive. The boost bypass id look for used as they are PRICEY at ford .. you can order those parts from ford .. the controll cable is like 30 bucks and idk about the tps but id look around that site above before buying anything new. |
Safud: MM's Resident Hadji
Boost bypass - typically around $35 from SVTP
IAT - VMP Tuning (make sure you get the threaded version) MAF Flange - VMP Tuning TPS and cruise control bracket - SVTP PCV Delete - VMP Tuning (or make your own...just breather valve and a cap to block off the port on the intake) |
for the MAF flange which one do i need? And why do i need one? Isnt the 90mm maf housing and everything fine???
328/419 @ 4000 rpms
haha so i dont need one???
I never needed one. I think you would only need it if your routing your filter into your fender, but im not sure
2003 mustang v6
232rwhp@7psi
for the m112 kit i don't believe you HAVE to have one.
V0rTech'D
328/419 @ 4000 rpms
Im with them on this one, I never used mine nor do I think you need one.
Just letting everyone know the TPS sensor is the same at the V6's. I went to ford today and between a 2003 cobra and a 2001 mustang v6 they are the same part number. So just letting everyone know
what parts are in the boost bypass for the m112
Selling Mustang So Im Selling All M112 Parts |
Its just a valve...Buy one from SVTP for about $35 |
i cant find it anywhere on that site
make a WTB thread....there will be like 4 people replying to you by tomorrow lol
328/419 @ 4000 rpms
what does it do? I sent out somethin hopefully someone will respond
it releases extra boost
oh solid. yea im getting everything from that one list. Im about haft way there pay check comes tomorrow and everything else gets ordered up then
And for the IAT senor do i need to buy the connector piece to??
VMP Tuning - Buy Ford SCT & GM Custom Handheld Flash Tuners Performance Economy Towing: IAT/ACT Sensors
hmmm....99 and 00 stangs you dont since the IAT has its own harness, but i think in 01+ ford started to put the IAT into the MAF connector so yes. You will need the connector piece
Threads Similar to: M112 Questions
| M112 | Ticket-Me-Yellow | V6 Mustangs | 66 | June 21st, 2009 03:58 PM |
| m112 on a 2V ? | SleeperStang88 | 99-04 | 12 | June 9th, 2009 12:59 PM |
| m112 on v6 | SleeperStang88 | 4V / SVT | 3 | April 29th, 2009 01:30 PM |
| M112 on a 2V! Yes you Can!!!! | ohcat68 | 99-04 | 14 | May 2nd, 2008 09:16 AM |
| m112 | mmvi | V6 Mustangs | 34 | March 5th, 2007 03:38 PM |
