AC Help
Old July 2nd, 2009, 11:58 AM   #1
atc31510 is on a distinguished road
AC Help
First of all this site rocks and is full of good info.Newbie here with a AC question.My AC all of a sudden just stopped working.I can run a wire from the battery to the compressor and it will come on and cool.Could it be the Ac Cycle Switch not giving power to the compressor? Or where do I need to start? Thanks for any help
Old July 2nd, 2009, 12:02 PM   #2
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
Check the wires to start, do a continuity test with a multimeter, check fuses, everything electrical related. Even if it seems 100% not it check it anyways.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old July 2nd, 2009, 12:09 PM   #3
I will check the wires tonight as for the fuses they all check out good.Thanks for the reply.
Old July 2nd, 2009, 01:42 PM   #4
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
it's the low pressure switch. it's on the drier up by the firewall on the passenger side. it's a little plug that does into a schrader valve on top of the drier. un hook it and run wires from one side to the other. see if it gets cold then. if it does, then replace. it's a common issue
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old July 2nd, 2009, 02:50 PM   #5
Thanks I will give it a try.
Old July 3rd, 2009, 12:02 AM   #6
4.6L Coupe' 5spd
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
Yeah, I'm pretty sure its want ginky said, I also have that problem and that's what they told me. I just snap that box with my hand and then it works try that but don't hit it too hard...
Old July 6th, 2009, 10:19 AM   #7
No luck with the ac cycle switch put in a new one no ac.I checked to see if I am getting power to the compressor and it show 13.xx volts till I plug up the wire then it drops to nothing. Could it be the relay box that is in the passenger side fender? I am not sure of the correct name. Thanks
Old July 6th, 2009, 05:55 PM   #8
4.6L Coupe' 5spd
Did you try hitting it? that's what I what I thought gunky said yes thats a 10 dollar part... Just go to autozone they will know the name.....
Old July 6th, 2009, 06:22 PM   #9
Graypony's Avatar
Graypony is on a distinguished road
Could be your system is low on charge. There are high and low pressure switches that control the compressor to protect the system should pressure be too high or low. If you jump the low pressure switch and the compressor starts the system needs an evac and recharge. On the high pressure side could be a clogged receiver drier or pinched hose if jumping the high pressure swich starts the compressor.
Old July 7th, 2009, 09:04 AM   #10
I jumped both high and low switches and nothing .If I run a wire from the battery to the clutch it will come on and cool. Checked coolant level while I had compressor on and it is good.
