MM's Database Error
car running weird after fill up
its been doing this for a while and i cant figure out for anything what it is. after putting gas in the car (whether its a lot or a little) it still runs rich and will fumble over itself at idle. drives fine but still stumble a good bit for about 4 or 5 minutes after putting gas in the car.
i've tried getting gas at the same place several times, getting it different places, etc. but it still does it. once that 4 or 5 minutes is up it gets itself straight and doesnt do it anymore but for some reason right after i fill up it runs bad. any ideas?
3.9L V6
b4 you said you went to different places i almost thought you accidently put the highest grade in there and maybe something was just off from it....sry johnson im not much help right now
[SIGPIC][/SIGPIC] 6k HIDs - Rear Sway Bar - Mac Prochamber - Goodridge Gstop SS Lines - Lots of Visual Fun - Go Fast Mods (no point in buying...it's a v6) Want to see your car as art...ask me how |
MM's Official Lucifer
Weird that it runs fine after a few minutes...I mean beyond your tune (I'm not much help in that area) I would go over everything fuel related, filter, lines, injectors (clean & functioning)... but still odd if it were one of those that it's no issue after warming up. That's a tricky one.
"Fast she goes...in the city of Overdose" ![]() |
1994 Ford Mustang GT
well when you open your gas cap its releasing all that pressure that was inside the tank, after 5 minutes it builds it up again and starts working fine, that would be my guess
www.moddedmustangs.com |
^ But does this happen to your car? Not mine, so I wouldn't just pass it off as normal function, pressure should build up again rather quickly when restarting.
also id try throwing a bottle of heet in it, you could possibly be mixing everything in the bottom of the tank with the new gas, you might have alittle bit of water in there that sits on top of the gas like little bee bees and are getting sucked in
thats what im saying, his might not be building up as quickly as most cars because his cap might not seal tight or he might have a slow leak some where
^ Ok I got you now, it seemed like you meant it was just normal, but a leak is indeed possible, why I said check all fuel components, still an odd issue.
MM's Database Error
thas kinda what i thought that there could be something in there acting up along with the gas. as far as i know there are no leaks. i mean it goes rich for i would say that its plenty fuel. the water thing might be it. not sure how it would have gotten water in but that kinda makes sense. how much of that heet are you supposed to put in? and is that stuff still safe for the turbo.
MM's Resident Ricer
2006 Scion tC
13.001@113
are you going places that sale that ethanol crap? I know my tc stumbles for the first little bit after getting premium from those places no idea why but after 5 or 6 mins its fine
MM's Database Error
yea i cant find places without it. but that sounds like my problem ecept the stumbling is pretty harsh
Have you tried takeing the fuel cap off then putting it back on to see if it still does that? Try that, and check the fuel cap for any damage.
![]() Black Stang Crew #007 Car Built By Me and CraigsList.com Mods: MGW, Bassani Catted X, Flowmaster's, Accufab 70MM TB, Stack Racing Plenum + spacer, JLT CAI, Diablo Tune, Slotted rotors + ceramic pads. More to come! I hope.
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah mine is too feels like a bad vacuum leak or a nasty misfire my shop just said it takes a bit for the PCM to figure out the e-10 based fuel
MM's Database Error
yea exactly...hmm so i guess its really nothing i can do about it if its that...just have to search for the better gas
Threads Similar to: car running weird after fill up
| car running weird | Codeman | V6 Mustangs | 19 | May 8th, 2009 06:16 PM |
| car running weird | DeMello | The Clubhouse | 55 | July 5th, 2008 03:44 AM |
| car acting weird | shadow5403 | V6 Mustangs | 6 | May 15th, 2008 12:57 PM |
| running weird?? | mustangrebuilder | 2005 - 2010 | 18 | April 23rd, 2008 02:54 PM |
| !!! (Weird Car) | mustang1072 | All Other Vehicles | 7 | January 30th, 2007 09:10 PM |
