Discussing unknown whine in the V6 Mustangs Forum. so theres a whine that usually occurs under 20 mph. at first i thought it ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1998 Mustang V6
unknown whine
so theres a whine that usually occurs under 20 mph. at first i thought it might be the transmission so i checked the fluid and it was at about 15%, so i topped it off and now its at 100% but it still makes the whine. my hunch is that its more than just low fluid, but is that hunch wrong and can it be something else?
auto or manual?
1998 Mustang V6
auto
MM's Resident Ricer
2006 Scion tC
13.9@103/8.9@81
check your belts and power steering
![]() Scion Tc-going turbo ![]() MM 4 Banger club: Senior Ricer buy my nitrous http://www.moddedmustangs.com/forums...-kit-sale.html "Horsepower sells cars, torque wins races." -Carroll Shelby |
1998 Mustang V6
belts were actually my second guess, i ruled them out before checking. power steering is fine, i topped off all my fluids last weekend
Our power steering almost always whines.
MM's Resident Ricer
2006 Scion tC
13.9@103/8.9@81
well bad fluid in the P/S will whine horribly too if you have never had it flushed i would recommend it and check ur pump
2000 V6
Check your rear end... your car's rear end.
~For Newbies: Rep are those little green squares, to give reputation click the gray scale, under the person you want to rep, then write why & name. ![]() Looking & buying soon a 01-04 Mustang GT
1999 Mustang V6
yea at slow speeds in first gear iv always had a slight whine. i dont think it means anything. unless yours is different.
2000 V6
Oh I know what it is its your warped rotors, I also have that whine but I'm lazy to replace them, check them.....
Hmmm I'm not sure what it would be on an automatic. My car currently whines when the clutch is depressed, mostly likely due to a TOB that's "gone to the pasture". In your situation that's obviously not the case...
2003 Mustang V6
Mine has a whine in first gear under 20 mph too (auto), and my p/s whines too even though its had a flush and even has some Lucas p/s fluid added in (had it checked its working perfectly fine)
![]() 2003 Mustang V6 Shoppinglist: HID kit, 4.10 gears, t-lok, windstar, udp, cam, exhaust |
2000 V6
Check your rotors^ does it also make it when you let of the gas? The p/s whine its a common ford problem buying a new p/s pump will get ride of that...
2003 Mustang V6
I haven't paid much attention to it while rolling to a stop, but I know it doesn't make the noise in any other gear but first (or its just not loud enough for me to notice in the other gears)
#15 | |
2000 V6
By the way nice siggy...
#16 | |
2003 Mustang V6
All credit goes to 6er_w/a_Vengance hes the sig master
2003 Mustang V6
Actually now that I think about it my car does feel like it slows down really quick with my foot off the peddle. I had the rotors worked on pretty recently when I got the pads changed, they said they machined them but I guess that doesn't mean Sh*t if their warped does it.
#18 | |
2000 V6
2003 Mustang V6
Are their drilled & slotted rotors for the 6? I've only ever seen slotted.
#20 | |
2000 V6
Threads Similar to: unknown whine
| What gears don't whine | Quarters97gt | 96-98 | 14 | June 7th, 2009 02:23 AM |
| No Whine! | 07 Boss | 2005+ | 17 | May 29th, 2009 12:40 PM |
| Unknown Car? | 95StangMX | The Clubhouse | 22 | April 12th, 2009 06:11 PM |
| whine | mpboy | 99-04 | 8 | October 1st, 2008 11:48 AM |
| unknown whistling noise | 00gtCoolGuy | 99-04 | 9 | July 4th, 2008 08:29 PM |
