The Bottom Stock Project
Just as I rebuilt the built motor not but a few days later I purchased a new 2009 GT mustang. Because of this I can now do what I've always wanted to try.
500rwhp on a STOCK 01-04 V6 3.8L bottom end! The tearing apart of the built motor has already begun. With that motor I'am completely revising as well and constructing a new built motor while the stock motor is in play. how? new camshaft going in. probably a 218/218 .560-.570 lift 116-118 lsa area New turbo pt67 or a 70-72mm New big valve heads! SSX intake or a modified split port ported upper. ported lower 70mm accufab Comp rockers comp lifters 6300-6500rpm pull all on top of a stock bottom end from an 01-04 Fuel will have to be 110 or C16 first goal running-pump gas looking at 8psi 370-400rwhp area second goal after 1000miles of letting the bottom end see boost 110octane goes in 12psi 450rwhp goal min!! should be fairly easy and reasonable considering on smaller cam, heads, and turbo i made previously 439rwhp on 12psi with 100octane reving to just 6000rpms final goal 15psi 110 or C16 or Q16 500rwhp At this point i dont predict it'll last to long though. Im hoping it'll at least last 2weeks(4-6 days of racing) Depending how bad the motor blows if its just piston rings, i may just get some moly piston rings, cyro treat the rods and pistons and aim for anything higher. basically the rings and rods are the weak point on the motor. the stock cast I-beam rod is like a chicken bone supporting a human. it'll only last so long. which i may consider only going to 6000rpms because of this. Anyway once i find a stock bottom end the project begins!!!! The fate of the built bottom will stay under wraps as far as motor specs
1996 ford mustang
chris you are crazy as hell thats all i got to say .......
what happen to the 4.2? ......... mine should be done soon ill let you no the numbers |
#3 | |
in return cylinder 2's connect rod lost oil and spun. i put it back together but only have about 350miles on the new bearings I'am taking it apart, new crank, doing some other things to the crank, might go with different rods, also will be getting different pistons most likely. I'am debating on that one. but a few other things will be done to the entire motor. 100% correct like i really wanted it
Interesting....
2003 Mach 1 Procharged 500rwhp club
All i have to say is have fun!?!? sounds doable
The difference between Fiction and Reality??? Fiction has to make sense. -Tom Clancy |
Moderator
2012 300a gt auto
12.10@116
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
boosted v6
11.90@114
nice let the battle of the stock bottom ends begin... migth i say your nuts for pushing a stock bottom that far but it'd be nice to see it done
![]() 3/4 turbo stang Last edited by 96b.boy; July 11th, 2009 at 11:53 PM. |
Good luck chris
#9 | |
But remember. at 439rwhp when i took apart my motor. that motor looked in AWSOME condition, bearings were fine, rods and pistons looked in very good condition. just 1-2bad piston rings. if thats the case with 450 or 500rwhp, as to the only reason its blown. I'll throw some moly or gapless rings and cyro treat the rods and pistons, then turn around and go for 550ish. i have no idea how good that treatment will be on stock rods
Getting a windstar intake thrown on the car this time around
Im going to try to open it and make the throttle inlet bigger for it as well. test both the windstar intake and the SSX. SSX will probably go on the built motor though. But depending how well the windstar responds that might not even be needed. to many advantages to the windstar heat WEIGHT which is huge for me, I'am a power to weight nut. if its 2lbs off the front its coming off.
That will look great I hate our intake it looks bad, I was watching VAPs project dont remember if it was on 3.8 mustangs or stangnet.....
boosted v6
11.90@114
chirs the biggest tb you can fit on a windstar is a 70mm any bigger needs a spacer and bottle necks down .a stock 2v 4.6 tb is pushing it
![]() 3/4 turbo stang |
Threads Similar to: The Bottom Stock Project
| Stock bottom end build | evan | 5.0 Mustangs | 2 | April 14th, 2009 08:47 PM |
| How Much HP On Stock Bottom End | 5litercobra | 2.3 Mustangs | 5 | November 13th, 2007 02:55 PM |
| 12s with stock bottom end? | 95wip | 94-95 | 8 | April 16th, 2007 11:10 PM |
| How Much HP Can Stock GT Bottom End Take? | Clutchmaster | 99-04 | 14 | March 22nd, 2007 03:58 PM |
| Supercharger on stock bottom? | 95StangSVT | 5.0 Mustangs | 2 | October 19th, 2006 09:34 PM |
