tc sc
could someone please post up a part list for a turbo setup and or a supercharger setup for my sixer i really want to part a kit together
Safud: MM's Resident Hadji
For the M112 v
2003-2004 Cobra M112 Supercharger 2003-2004 Cobra plenum 2003-2004 Cobra throttle body 2003-2004 Cobra 39lb injectors Cobra 90MM MAF With MAF Sensor 2003-2004 Cobra boost bypass 2003-2004 Cobra supercharger pulley 2003-2004 Cobra throttle and cruise control bracket 2003-2004 Cobra air intake tube 2003-2004 Cobra TPS sensor 2003-2004 Cobra M112 supercharger gasket- RTV sealant works best 2003-2004 Cobra plenum gasket 2003-2004 Cobra throttle body gasket 2003-2004 Cobra fuel injector O-rings 1999-2004 Mustang V6 upper intake gasket M112 intake adaptor PCV delete 2003-2004 EGR delete IAT Sensor and Wiring CNC MAF flange 310lph fuel pump (98-04 cars) NGK TR7IX spark plugs Gatorback belt #4061182 or 6PK3002(metric part number) Air Filter With Filter Box M112 EGR delete 12 bolts for adapter to V6 lower intake 12 washers for intake bolts 10 bolts for M112 to adapter 4 bolts for the plenum to the M112 4 bolts for the throttle body to the plenum 4 bolts for the MAF to CNC flange 2 bolts for IAC delete to plenum 2 bolts for IAC relocation 2 bolts for IAT relocation to M112 2 bolts for Cobra throttle cable bracket 2 clamps for air filter Custom made pieces: Tuning EGR delete Coli pack bracket Radiator hose IAC relocation IAC block off plate Idler pulley setup IAT relocation plate IAT gasket Shave off intercooler lip Longer wiring for IAT relocation |
2003 mustang v6
232rwhp@7psi
for the vortech/procharger
1. voretch/procharger kit ![]() 2. fuel injectors 3. focus svt fuel pump/gt supercar fuel pump
V0rTech'D
#4 | |
and a supercharger kit ![]() im lost as to what your asking. most procharger kits are basically come with EVERY single component you will need, pump, tune, plugs and even injectors. as well as the s/c kit and bracket of course fuel wise 42lb injectors Ford GT pump(fuel pump) should cover you to 400rwhp then you just need a turbo kit...which should come with all the parts else you need also a MAF sensor.... i dont understand what your asking, its pretty open ended
in the end most v6 owners that actually do something will get a supercharger
In my opinion i would at least go procharger. Every tuning shop or performance shop I talk to has just about nothing good to say about Vortech kits. the common reply was, "vortech is more a budget kit you get just to say your s/c'd and have one. there nice but not great"
i was hoping to get a parts list for a supercharger kit as well as a turbo kit... im not getting both i just wanted a list for each sorry for the confusion
