Whats wrong with my car
Old July 10th, 2009, 08:48 PM   #1
2000 mustang v6
mustangv600 is on a distinguished road
I think its the fuel pump cause the car was acting fine anll day and I shut it off with it above E and then after I went back to start it up the car just doesnt keep running like there is no fuel the oil is fine and so is the trans fluid they arent burned or look funny, i think it really is the pump opinions???
Old July 11th, 2009, 12:36 AM   #2
ApeXX is on a distinguished road
Does it make a ticking sound, like a battery related problem?
Old July 11th, 2009, 03:03 AM   #3
03 Mach 1 & 02 GT
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
IF you hear a tick noise just by putting it on the ac position that's the pump starting, also push the pump switch located next to your fuse box, check your spark plugs and try putting more gas.....
2003 Mach 1 Procharged 500rwhp club
Old July 11th, 2009, 02:55 PM   #4
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
i would say that i would check for spark on the wires that is easiest. Then if it has spark i would check the fuel pump like they say. And if that is fine it would likely be a plugged fuel filter so i would change that.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old July 12th, 2009, 12:38 AM   #5
2000 mustang v6
Its the fuel pump
I took it to the garage today and it was the fuel pump they didnt have time to work on it but they told me the pump died they looked at it what are the odds that when ford changed my fuel filter last week it screwed up my fuel pump?
Threads Similar to: Whats wrong with my car
whats wrong? carlos 99-04 14 April 22nd, 2009 05:24 PM
car bucks at high rpms...whats wrong????????????????????????????????????????????? ???? random hero 5.0 Mustangs 7 June 12th, 2008 05:52 PM
whats wrong? superman5.0 5.0 Mustangs 5 January 1st, 2008 06:18 PM
whats wrong with my car? show95stang 5.0 Mustangs 17 December 22nd, 2007 07:05 PM
Whats wrong with my ac??? 99v6stang V6 Mustangs 6 May 11th, 2007 03:33 PM
