2004 Mustang V6 Coupe
Im makin waffles
Suspension Build Help
My car is still under warranty for another 3 years so instead of fuckin with the engine and exhaust for now I have decided to totally overhaul the suspension first. Im talking new performance brakes, rotors, springs, tower braces, camber plates, control arms, subframe connectors, bumpsteer kit, shocks and struts, and sway bars, and leavin the engine and drive train under warrenty.
I need help with who manufactures the best products for these different areas for a 2004 mustang v6
![]() Mark my words I WILL HAVE A MACH . . . but I gotta wait a few years first (college student = broke) |
on the suspension portion of that i would recommend just buying a kit all from one company it is recommended to stay with one company rather than have different suspension parts from different companies. And on the brakes idk unless you have plans to road race or make some serious power i would just recommend getting better pads there is no need to get new calipers with more pistons and slotted and cross drilled rotors. Unless you just like the look of the rotors.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
Im makin waffles
Thanks for the tip on the suspension, the reason I asked about brakes and calipers is cuz Im either going to eventually twin turbo my v6 or drop in a supercharged v8 with all the other necessary engine and drivetrain upgrades. So to put it simply I guess im lookin to overbuild a suspension so it could easily handle being abused by whatever power and torque I could get out of either the twin turbo v6 or a supercharged v8. This is my DD so I want a suspension that will not only perform to me abusing it on the track but also offer great performance on the street during rain, winding roads, and maybe snow on a day to day basis
![]() Mark my words I WILL HAVE A MACH . . . but I gotta wait a few years first (college student = broke) Last edited by Cincy6er; July 11th, 2009 at 03:35 PM. |
Or you can get the cobra upgrade everyone likes them.....
2003 Mach 1 Procharged 500rwhp club
Im makin waffles
Ok so while looking around I found this suspension kit by Maximum Motorsports:
1999-04 Mustang GT Maximum Grip Box includes * MM K-member (with 2-point brace) * MM Front Control Arms * MM Torque-arm * MM Panhard Bar * MM XL Series Full-length Subframe Connectors * MM Coil-over Conversion Kits, Front and Rear * Coil-over springs * MM Caster/Camber Plates * MM Aluminum Rear Lower Control Arms * Bilstein HD series struts * Bilstein HD series shocks * MM Adjustable Rear Swaybar * MM Aluminum Steering rack Bushings * MM Solid Steering Shaft * MM Bumpsteer Kit (adjustable outer tie-rod ends) * MM Strut Tower Brace * MM Front Swaybar Relocation Kit * Front Swaybar Bushings * Front Swaybar End Links The total package is $4,537.80 not including shipping, plus I would pay for the performance shop near me to swap everything out. Is this a pretty good deal or would it be cheaper to buy all the parts seperate??
![]() Mark my words I WILL HAVE A MACH . . . but I gotta wait a few years first (college student = broke) Last edited by Cincy6er; July 11th, 2009 at 04:55 PM. |
2000 Mustang
How much of a drop would you like?
![]() Detailing Crew Member North Carolina Modded Mustangs #5 |
Im makin waffles
less then a 2" drop
wow with a setup like that u'll be owing the road!?! While u'll be at it u should just get an 8.8......but I don't know if it'll void ur warraty!?!?
The difference between Fiction and Reality??? Fiction has to make sense. -Tom Clancy |
2000 Mustang
#10 | |
Im makin waffles
Right now Im planning on dropping in a 351w when the 6er craps out, but its gonna be a while before that happens so I wanna get all the suspension work done first so that way when I get the 351w pushin 400hp I can just drop it in with the rest of the swap parts and be ready to haul ass
![]() Mark my words I WILL HAVE A MACH . . . but I gotta wait a few years first (college student = broke) Last edited by Cincy6er; July 12th, 2009 at 12:45 AM. |
Im makin waffles
I am leading up to a 351w swap so an 8.8 rear is pretty much required for swap so i was gonna get it then
![]() Mark my words I WILL HAVE A MACH . . . but I gotta wait a few years first (college student = broke) Last edited by Cincy6er; July 12th, 2009 at 12:03 PM. |
This article will give you some idea of what can be done to the Mustang suspension. Notice that it discusses suspension modifications needed when the car is lowered.
Late Model Mustang Suspension Basics As to brakes, there are already dual piston calipers in front, which should be adequate. As someone else said the most you might want to do is to go with better pads and possibly slotted rotors, |
Im makin waffles
That article was a big help. Before I new what parts I needed but I didnt know why they were important to the overall performance of the suspension, Now I do so thanks again
#15 | |||
The ProKit does not notably increase the spring rate, so it is not the best choice for handling improvement. The ProKit is a good choice if you're looking for an inexpensive way to lower your car. If you want handling, there are better choices... if you are looking for lower AND significantly better handling, there are better choices. NONE of the above items are "only needed at really high hp levels." If you're looking for a really tight, quality suspension setup in your Mustang, that is a good list to follow whether you've got a 600hp KB Cobra or a 100hp 4-cylinder Fox.
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles 2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP) 2001 Harley Davidson F-150 Acts 16:31 |
#16 | |
2000 Mustang
your looking at an easy $1500-2000 in suspension
might as well look into just a full steeda kit honestly most have shocks, springs, roll bar, sway bars, plates, bushings, control arms and everything your looking for
#18 | |
Priest of the Car Gods
![]() oh please explain let him piece everything seperate and spend another $200-600 on parts
Oh, I agree he should get a kit, just not anything made by Steeda.
Threads Similar to: Suspension Build Help
| Steeda Suspension- Suspension Questions | MustangJon255 | 2005 - 2010 | 22 | June 2nd, 2010 05:43 PM |
| The Build | Procharged 347 | 5.0 Mustangs | 33 | June 8th, 2009 09:39 PM |
| 5.4 4v build | GTsetGO | 4V / SVT | 23 | March 7th, 2009 06:44 AM |
| well its my first build.... | 92lxhatch | 5.0 Mustangs | 14 | February 11th, 2008 10:24 PM |
| just about to build | fastpony | V6 Mustangs | 11 | December 30th, 2006 01:59 AM |
