help
Old July 13th, 2009, 09:33 PM   #1
Stang Tech's Avatar
2003 Mustang GT Vortech
Stang Tech is on a distinguished road
Send a message via AIM to Stang Tech
help
Today I started my 99 v6 and just after i started it while idling it was shaking badly. then once i got it into reverse it went away. anytime i started after that it doesn't shake. Any info would be helpful
thanks
Ford Certified Tech Land Rover Certified Tech
Ase Certified Tech Honda/ Acura Certified Tech
AllData Automotive Information Specialist
03 Mustang GT
Vortech V3 Intercooled
407/415 to the wheels
BOOOOSSSTTTTTT
Old July 13th, 2009, 09:44 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
So, it's not doing it anymore?
O o
/¯/______________________
\_\
Old July 13th, 2009, 09:45 PM   #3
Stang Tech's Avatar
it does it when i let the car sit for a while. once started doesn't do it.
03 Mustang GT
BOOOOSSSTTTTTT
Old July 13th, 2009, 09:53 PM   #4
What do you mean by "sit a while"? Does that mean like a week, or just long enough for it to be totally cold?
Does it just do it in Park? While it's shaking, if you put it in reverse and back to park, does it start doing it again?
Where does the shaking seem to be coming from? What sort of frequency? Does it increase with rpms, or go away if you hit the gas?
O o
\_\
Old July 13th, 2009, 11:20 PM   #5
Stang Tech's Avatar
if let the car sit long enough to cool done. only does it in park right when i start it up. it shakes the whole car it kinda of goes away when you hit the gas. seams to be from the engine. and once it goes into drive it doesn't come back if i put it in park.
03 Mustang GT
BOOOOSSSTTTTTT
Old July 13th, 2009, 11:22 PM   #6
Does it go away if you let the car warm up? Or does it shake until you do something?
O o
\_\
Old July 13th, 2009, 11:49 PM   #7
Stang Tech's Avatar
goes away as like 5 sec's after going into any gear and doesn't not return.
haven't tried just letting warm all the way up and seeing if it still happens
03 Mustang GT
BOOOOSSSTTTTTT
Old July 13th, 2009, 11:52 PM   #8
Okay, when's the last time you ran some fuel injector cleaner through it (Lucas ftw), or seafoamed it?
O o
\_\
Old July 14th, 2009, 12:42 AM   #9
Stang Tech's Avatar
i just ran some Lucas on Saturday. I will run some more tomorrow to see.
03 Mustang GT
BOOOOSSSTTTTTT
Old July 14th, 2009, 01:03 PM   #10
03 Mach 1 & 02 GT
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
Have you done a tune up? replaced the pcv valve? check for leaks, inspect your spark plugs and wires, sea foam will be a good idea......
2003 Mach 1 Procharged 500rwhp club
