I have a few modding questions - Page 2
Old February 2nd, 2007, 04:55 PM   #21
Redline is on a distinguished road
no but when OD is on I really do hear and feel the gears change.. I've been driving with it on for some time now.
2000 3.8l mustang v6 automatic - Stock.
Old February 2nd, 2007, 04:56 PM   #22
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
i feel mine change all the time lol ive never heard any noise from my tranny tho
Old February 2nd, 2007, 04:58 PM   #23
no I mean the engine makes a deeper noise when it shifts gears because rpms drop thats what i ment not from the tranny.
Old February 2nd, 2007, 05:06 PM   #24
06 Satin Silver V6
9.440 @ 71.27 1/8th mile
XxViSiOnxX is on a distinguished road
Send a message via AIM to XxViSiOnxX Send a message via MSN to XxViSiOnxX
well lets start from the top!
when you get in your car and start it does your OD light automatically come on?? if yes then just leave it as it is wether you race or not turning it off just means you will be running with no overdrive you dont lose and hp or anything like that just wont pick up as quickly.
MODS: In Garage
Old February 2nd, 2007, 05:07 PM   #25
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
it shouldnt act differently. it just keeps you out of your overdrive (4th) gear
ModdedAutos
1999 Mustang V6
Old February 2nd, 2007, 05:08 PM   #26
14.79 @ 92.15
no. it will "pick up" the exact same unless tuned otherwise.
ModdedAutos
1999 Mustang V6
Old February 2nd, 2007, 05:11 PM   #27
When I start my car the "O/D OFF" light is not light up, so it must be on and you guys said that when it's on it only uses 4th gear which doesn't make sense since I know it flips gears.
Old February 2nd, 2007, 05:14 PM   #28
14.79 @ 92.15
no. it uses 1-2-3-and 4 when od is on.
you must turn od off because it is on as default.
when off, it uses 1-2- and 3.
ModdedAutos
1999 Mustang V6
Old February 2nd, 2007, 05:20 PM   #29
06 Satin Silver V6
yes exactly what blue said, and was kinda were i was headed but needed more info from start.
MODS: In Garage
Old February 2nd, 2007, 05:21 PM   #30
Juggalo_X's Avatar
14+@Slow
+1 100% correct!
Bottom line guys and read carefully here when overdrive is deactivated the only thing this does is stop the transmission from switching into your 4th gear (OD gear) bottom line it don't affect acceleration or any of that so stop saying it stop thinking it and stop telling the poor guy it your confusing the shit out of him god damn do people not read my posts or AtlanticBlue99's posts. the only advantage of switching the overdrive off is allowing your car to stay in the 3rd gear in its power band at the high rpm. INSTEAD of switching into the 4th gear (again OD gear) which is meant for economy and is a more relaxed gear ratio. Bottom line
Old February 2nd, 2007, 05:22 PM   #31
Oh ok well now it makes sense all that talk about my trans being bad had me worried. So what's the point to turn OD off, how fast do you have to be going to flip into 4th gear I never payed attention to that.
Old February 2nd, 2007, 05:24 PM   #32
Juggalo_X's Avatar
14+@Slow
your car will hit OD whenever your accelerator is in a cruzing (non accelerating ) position it helps save fuel thats all.
Old February 2nd, 2007, 05:36 PM   #33
Ok I think I finialy under stand! What my understanding is that with OD on you use all gears 1-4 and if you are just crusing then it will flip into 4th gear. Now with OD off it will go through only the first 3 gears and if you are crusing it will not flip you into 4 gear. So with racing it doesn't matter if OD is on or off because your rpm will be high. Is that all right?
Also what would happen if you are driving with OD off and you are near the top speed for your 3rd gear? would the rpms just get higher and higher and bounce off the limiter ?
Old February 2nd, 2007, 06:35 PM   #34
Juggalo_X's Avatar
14+@Slow
eventual ur tach limit will be hit and u will rev down
Old February 2nd, 2007, 10:28 PM   #35
niners2046 is on a distinguished road
your thinking way too into it
Old February 2nd, 2007, 10:36 PM   #36
Juggalo_X's Avatar
14+@Slow
you get educated by asking questions don't criticize him
Old February 3rd, 2007, 02:09 AM   #37
punkafi888 is on a distinguished road
ya man, its all in your head. hit up wikapedia and find out how an auto works. and it does sound like you have a trans problem. take samples from your trans and look for shavings. or if its dark. just change it. i have a 2k1 5-speed. and if my car gets a slight tint in the trans fluid i change it. thats just cause i race a lot. and as for the stiffer pedle/ when you hit the od button does your floor mat move a little? lol just kidding, its all in your heads man.
Threads Similar to: I have a few modding questions
New To Modding, What Do You Think? Dbarker 99-04 22 January 21st, 2007 01:00 PM
What To Do, Help (Modding) DeathScythe95 V6 Mustangs 24 January 14th, 2007 04:24 AM
Modding My Car trueballerisme 2005 - 2010 8 December 29th, 2006 06:41 PM
Need Some Help (Modding) mustang96 96-98 4 November 9th, 2006 01:37 PM
Some modding questions from a total newb - 2002 mustang v6 Jadugar V6 Mustangs 8 June 25th, 2006 02:07 PM
