Cam Bearing Failure
Old March 2nd, 2006, 08:52 AM   #1
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
Cam Bearing Failure
so broke apart my first motor last night, before teardown noticed a ticking/chirping sound coming from the motor, originally beleived to be a bad pulley or related to the a/c system, after still hearing the noise when running the motor with the serp belt off we thought it was a spun bearing or something related.
so once we pulled the cam we saw issues at a few of the cam bearings and we first thought we damaged it with removing the cam, but after we pulled the block and upon further inspection it appears as a few of the bearings started to decentagrate and not just at the oiling holes, but did not see any major problems on the cam journals. i tried to take a picture but couldn't get the camera to focus in.
the oil pickup screen had parts of bearings stuck to it.
my question is what causes something like this, heat? oiling? over reving? or debris in the oiling system? we are gonna put in some performance bearings and are getting the cam reground anyways to work with the stroker kit.
Old March 7th, 2006, 07:31 AM   #2
guess it was just a crappy bearing, hopefully the performance bearings will last longer... oh well the block is at the machine shop getting prepped for a 408 stroker with new bearings.
Old March 7th, 2006, 12:37 PM   #3
vfast will become famous soon enough
I would say due to low oil pressure....what was in the screen..my guess some valve seals..etc?
Old October 31st, 2006, 10:35 PM   #4
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
how much does it cost to fix when the bearing goes out?
Old November 1st, 2006, 07:21 AM   #5
before replacing the bearing i would atleast try to run the motor with the belt off to help diagnose where the sound is coming from... but depends on how you get it done, the cam bearings themselves are not that expensive if your doing it yourself... however you still need to tear down the front of the motor which includes the cooling system, waterpump, timing cover, chain, cps, and fluids.... then you will need to rent a cam bearing installation tool from your local parts store.
personally if i spun or lost a bearing i would get a reground cam and new bearings/springs from somewhere like rpm-mustangs.com and replace it with those.
this post should give you a general understand on what is required during the install: http://www.moddedmustangs.com/forums...gh-vt3760.html
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old November 2nd, 2006, 02:14 AM   #6
stang fanatic's Avatar
stang fanatic is on a distinguished road
cams tend to knock, and bearng failures of any sorts is from lack of lube for whatever reason...plugged oil holes, incorrectly installed bearings, age, etc. ....Cam bearings tend to last the longest since traditionally it doesnt recieve the same type of force on it as a rod or main bearing
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Threads Similar to: Cam Bearing Failure
Random Failure? MSTGGT00 99-04 9 September 15th, 2007 03:52 PM
drag day...failure itschristorres8 Drag 16 July 26th, 2007 01:04 AM
odometer failure Plays With Squirrels 96-98 22 July 6th, 2007 09:41 PM
Failure.......*tear* lwhitetrash88l V6 Mustangs 30 April 14th, 2007 09:19 PM
How can you test for IAC failure ? Ga_50_foxbody 2.3 Mustangs 8 April 10th, 2007 12:58 PM
