#281 |
ok finally took the time to do videos today. Hope these help get an idea.
Selling Mustang So Im Selling All M112 Parts |
#282 |
#283 |
Safud: MM's Resident Hadji
Have you got a tune yet? If not, then you really shouldn't be revving your car up like that
#284 |
nope i dont. i just did it to show you guys
#285 |
You should get a tune first....The smoke problem will more than likely go away if your car is running exactly as it should
#286 |
yea thats what i was thinking but other people on here thought i could fucked something up (idk how i would've) and said i should do a compression test and one other test
#287 |
i really would not have thought that you would have messed something up. i would definately be carefull with driving your car without the tune. i understand how it would be tempting with doing all of the new upgrades, but just think that it aint worth having to redo it all. if you want you could do the compression test it is pretty simple, or you could consider getting a safety tune. until you can afford a dyno tune.
![]() UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors Great Automotive How To's http://tooldesk.com/blog/ |
#288 |
Thats what im going to do. Im getting a tune from trick tunes at the end of next week. and im currently not driving it so im fine for right now.
#289 |
2003 Mustang GT Vortech
I am saying do a compression and CLT test just to make sure since u did say u have been driving the car with out a tune. and where getting spark knock. I work on ford's and land rover's so i am just saying check before u pay for a tune.
Ford Certified Tech Land Rover Certified Tech Ase Certified Tech Honda/ Acura Certified Tech AllData Automotive Information Specialist 03 Mustang GT Vortech V3 Intercooled 407/415 to the wheels BOOOOSSSTTTTTT
#290 |
Don't boost that motor until you get the tune bro..
for real.
#291 | |
#292 |
[8MINUS2]
Is your a/f gauge wide band or narrowband?
#293 |
i believe narrow. Its not the upgraded one with the middle.
#294 |
[8MINUS2]
Your going to need a wideband for mail order tuning.
#295 |
Do you have the drivers side valve cover hooked between the TB and SC? If you don't, that is excessive, compression test as mentioned. If you do, you've got problems. And get a wideband, that was a 0-1v o2 your running, worthless for tuning anything but idle and cruise, more of an idiot light than anything else.
#296 |
No i believe i mentioned that im running breathers on each valve cover. But actually there into an oil catch can
#297 |
2003 V6 Mustang
14.2 @ 96
Dont know when you are going to start listening, but you NEEEEEED to get a compression test + tune. We cant help you.
#298 |
[8MINUS2]
+1000000
#299 |
2003 V6 Mustang
14.2 @ 96
A lot of your problems probably would have fixed themselves if you had gotten a tune right away. In fact im not trying to negitively say this but, you should have had the $ for the tune before even installing the eaton.
Im not sure what was up with your tranny. Its one hell of a coincidence that RIGHT after you installed your eaton, that your tranny was acting up. Im willing to bet it was not your tranny at all, and again had more to do with the tune than anything. Especially after hearing that all they did was replace the pump and gaskets. Im almost certain that if the pump was dead you would not be able to shift into any gear. But anyway those are just my personal thoughts. I feel your pain though, or will soon, as I am just about to start building my eaton setup as soon as my intake adapter gets in and I can get the time/money for the install. |
#300 |
thats an incredible amount of blow by out the catch can..thats not normal
do a compression check ASAP
Threads Similar to: M112 Build
| My M112-V6 Build | plove71387 | V6 Mustangs | 148 | November 1st, 2011 06:01 PM |
| M112 | Ticket-Me-Yellow | V6 Mustangs | 66 | June 21st, 2009 04:58 PM |
| m112 on a 2V ? | SleeperStang88 | 99-04 | 12 | June 9th, 2009 01:59 PM |
| m112 on v6 | SleeperStang88 | 4V / SVT | 3 | April 29th, 2009 02:30 PM |
| m112 | mmvi | V6 Mustangs | 34 | March 5th, 2007 04:38 PM |
