M112 Build - Page 19
Old November 30th, 2009, 10:34 PM   #361
mcmotors is on a distinguished road
Originally Posted by Ticket-Me-Yellow View Post
cause i either want to get a v8 in her or rebuild the shit outta that motor
No replacement for displacement... 5.4L, that v-6 would probably cost as much to rebuild if you did it right, let alone try to build it. If your going to swap the motor, do it right.
Props if you want to keep the V6... I'm building a 2.9l Ford from a Ranger, MP90 SC 5 speed 4wd in my jeep, just to be different. I could more easily take the SBC out of the corner of my shop, smack a blower on it and drop it in, probably easier, defiantly cheaper, or even go TT for even less and be like everyone else...
Which ever you decide, if you need custom parts, PM me, I'm a machinist and fabricator, certified welder. Anything is possible.
MC
Old November 30th, 2009, 10:38 PM   #362
Ticket-Me-Yellow's Avatar
2001 Mustang V6
14.89@93 mph
Ticket-Me-Yellow is on a distinguished road
Send a message via AIM to Ticket-Me-Yellow
thanks man. Im looking into the 4.2l, 4.3l kits just idk which one would be best and idk what other parts i would need
Selling Mustang So Im
Selling All M112 Parts
Old November 30th, 2009, 10:39 PM   #363
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
yea but the smoke started right when i put boost into the engine. Is there any motor besides the terminator motor that i could use that supercharger?
Exactly...You shouldn't have gotten into boost at all without a tune.
I'm down with the 5.4l swap though Do it!
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old November 30th, 2009, 10:42 PM   #364
Stang Tech's Avatar
2003 Mustang GT Vortech
Stang Tech is on a distinguished road
Send a message via AIM to Stang Tech
Tried to tell you i have worked on those car's at ford you give them any boost with out a tune and you will cause damages. Sorry to hear thou you can contact SSM and go with a built 4.2L that will be strong enough for boost or get a junk yard motor and boost that the stock block and internals can take about 8psi but thats with a tune and the right plug's and fuel 91 or higher.
Ford Certified Tech Land Rover Certified Tech
Ase Certified Tech Honda/ Acura Certified Tech
AllData Automotive Information Specialist
03 Mustang GT
Vortech V3 Intercooled
407/415 to the wheels
BOOOOSSSTTTTTT
Old November 30th, 2009, 10:44 PM   #365
2001 Mustang V6
14.89@93 mph
If im swappin motors its going to be a mach 1 or a terminator. Im favoring the 4.2, 4.3l kits. Whats the difference?
Old November 30th, 2009, 10:45 PM   #366
2001 Mustang V6
14.89@93 mph
whats the difference between 4.2L and 4.3L from ssm
Old November 30th, 2009, 10:47 PM   #367
Stang Tech's Avatar
the 4.3L is the same as the 4.2L just the block is bored out if you go mach or termi you will need to do a lot of work you need a different k member and all the computers and wiring for those motor's it's a big job just finished throwing a mach motor in a kid's v6 cost him labor alone almost 20 grand and he also had to buy a k member and new computers you best beat for the money is going with a 4.2L kit from ssm and then going F/I the kit from ssm is made to handle boost.
03 Mustang GT
BOOOOSSSTTTTTT
Old November 30th, 2009, 10:57 PM   #368
1996 Mustang Cobra
atlanticblue98 will become famous soon enough
Originally Posted by Stang Tech View Post
if you go mach or termi you will need to do a lot of work you need a different k member...
all 96-04 K-members are the same
1996 Cobra Coupe-#3779
Laser Red, Saddle Leather-1 of 994
1998 Atlantic Blue V6- R.I.P.
11/1997-3/3/2010
Old November 30th, 2009, 10:58 PM   #369
Stang Tech's Avatar
yes the 96-04 k memebers are depending on what type the gt is different then the v6 the mach1 is different then the v6 I work at FORD and know this.
03 Mustang GT
BOOOOSSSTTTTTT
Old November 30th, 2009, 11:05 PM   #370
1996 Mustang Cobra
For a Ford technician, you seem to need quite a bit of help wth your car
random engine problem - 3.8 Mustang Message Board
94-95 is one group. all 94-95 factory V6, GT, and Cobra k-members are the same
96-04 is the other group. all 96-04 factory V6, GT, and Cobra k-members are the same
if you want to put a 3.8 in one of those cars you can use either k-member. just buy 3.8 mounts that match the year of the k-member.
if you want to put a 5.0 or 351 in one of those cars you must use a 94-95 k-member. use 94-95 5.0 mounts.
if you want to put a 4.6 or 5.4 in one of those cars you must use a 96-04 K-member. use 96-04 4.6 mounts
11/1997-3/3/2010
Old November 30th, 2009, 11:26 PM   #371
Stang Tech's Avatar
that was when i was away form the shop and had no tool's at all and need to drive about 200 miles back home. Now would you like to dig up more shit cause you seem to have a problem with me.
03 Mustang GT
BOOOOSSSTTTTTT
Old November 30th, 2009, 11:33 PM   #372
1996 Mustang Cobra
i didnt have a problem until you pulled the "im a Ford tech, i know more than you" bullshit.
i have seen plenty of techs who dont know shit, why should your word be better than mine?
if tech are so great, then why did they try and program my 98's keyless entry remote using the 99-present programming procedure? see that it didnt work, then proceed to tell me my car doesnt have keyless
why did they replace my father's front driver's strut in his 2007 because of rattling when it was actually the power window buttons rattling in the door panel?
oh you must have been away from the shop for quite a while...
need help - 3.8 Mustang Message Board
11/1997-3/3/2010
Old November 30th, 2009, 11:47 PM   #373
Stang Tech's Avatar
I didn't mean it like that i just was trying to help the guy out. My bad but fuck it hate me and hate all tech's in the world
03 Mustang GT
BOOOOSSSTTTTTT
Old November 30th, 2009, 11:53 PM   #374
2001 Mustang V6
14.89@93 mph
ok you too take it somewhere else.
But what ssm f/i kit would i need? I mean if im gonna do this i want to do it right.
and for the 4.2L do i still have to bore out the cylinder?
Also after all of this what size pulley could i run on the supercharger?
Old November 30th, 2009, 11:54 PM   #375
Stang Tech's Avatar
go to the ssm website you don't have to bore the cylinders unless they are damaged. check out the site and email ssm if you go with a built internals i think you should be good for like 18psi with the correct injector's and maf and tune
you will need to bore the block if you want to go to 4.3L or if the cylinders are damaged
here's the list from there website on the internals
http://www.supersixmotorsports.com/p...dInternals.pdf
03 Mustang GT
BOOOOSSSTTTTTT
Old November 30th, 2009, 11:54 PM   #376
2001 Mustang V6
14.89@93 mph
stang tech what ford do you work at? Do you live in chicago or just the area?
Old November 30th, 2009, 11:57 PM   #377
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Whatever you do 4.2 or 4.3 your going to have to bore the block...
from ssms the 4.3Long rod apparently uses longer rods, different than the 4.2... Then your going to need a shop to put everything together, prob gonna want new cam bearings while your in the motor. And if your tearing into it this deep may as well do heads/cam while your at it to save labor. Full gasket set, all that fun stuff
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old November 30th, 2009, 11:59 PM   #378
2001 Mustang V6
14.89@93 mph
haha oh i no i just love the thought of pulling my motor
Old November 30th, 2009, 11:59 PM   #379
Stang Tech's Avatar
i am in the area i used to be at golf mill ford left now i am in peoria
and yes you will need to bore the block since you want to make sure you have the proper sealing with the new piston rings
03 Mustang GT
BOOOOSSSTTTTTT
Old December 1st, 2009, 12:02 AM   #380
2001 Mustang V6
14.89@93 mph
oh yea i just love the thought of all of this. Really wanted to buy a motorcycle but looks like im going to end up selling the dirt bike. Gay!
Threads Similar to: M112 Build
My M112-V6 Build plove71387 V6 Mustangs 148 November 1st, 2011 05:01 PM
M112 Ticket-Me-Yellow V6 Mustangs 66 June 21st, 2009 03:58 PM
m112 on a 2V ? SleeperStang88 99-04 12 June 9th, 2009 12:59 PM
m112 on v6 SleeperStang88 4V / SVT 3 April 29th, 2009 01:30 PM
m112 mmvi V6 Mustangs 34 March 5th, 2007 03:38 PM
