M112 Build - Page 2
Old July 29th, 2009, 09:48 PM   #21
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
Hey yellow...If you want the little EGR delete kit I have one i can hook you up with.
Comes with gasket, block off plate for the manifold, rubber cap for vacuum line, and a cap for the hole on the headers
Originally Posted by 06RedfireGT View Post
Hell, I'd suck his dick on TV for 52 cents lol
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old July 31st, 2009, 02:39 AM   #22
Ticket-Me-Yellow's Avatar
2001 Mustang V6
14.89@93 mph
Ticket-Me-Yellow is on a distinguished road
Send a message via AIM to Ticket-Me-Yellow
shouldve told me earlier i wouldve! But no i got everything settled. Still donno what to do with that sensor that was mounted on the pipe. I can take a picture of it tomorrow if you guys donno what im talking about.
Selling Mustang So Im
Selling All M112 Parts
Old July 31st, 2009, 02:46 AM   #23
2001 Mustang V6
14.89@93 mph
IAT sensor. Where does that go? Where does it connect up too?? Also the hood. Will both of these fit my supercharger? My adapter i got from lil rousch from 3.8mustang. He said it was the low profile one that came off his car. He had the normal cobra R hood.
Kaenen Mustang 95 Style Cobra R Hood (99-04) at AmericanMuscle.com - Free Shipping!
Cervini's 1995 Style Cobra R Hood (99-04) at AmericanMuscle.com - Free Shipping!
Old July 31st, 2009, 05:06 AM   #24
Safi's Avatar
00 v6 & 99 Cobra
You will need atleast 2.5" rise.
Also for the IAT you are going to want to drill a hole for it in the adapter plate. It MUST be AFTER the compressed air.
Just mount it in the front of the intake adapter and you're good to go
As for the EGR stuff....Just take all that shit out, as its not needed.
Old July 31st, 2009, 08:49 AM   #25
2001 Mustang V6
14.89@93 mph
what about the electrical connection??
Old July 31st, 2009, 08:51 AM   #26
2001 Mustang V6
14.89@93 mph
do i use that for the IAC?? Cause they are the same connector
Old July 31st, 2009, 08:56 AM   #27
Safi's Avatar
00 v6 & 99 Cobra
what electrical connector?
The IAC has nothing to do with the IAT
Old August 1st, 2009, 02:05 AM   #28
2001 Mustang V6
14.89@93 mph
pictures tomorrow haha but will both of those hoods work????
Old August 1st, 2009, 04:05 PM   #29
stephen has a spectacular aura aboutstephen has a spectacular aura about
I had to remove the right side manifold along with the EGR tube and separate them out of the car. To do that you need to remove the exhaust manifold studs which can be done with a 5mm socket. It will help some to unbolt the converter assembly and drop it down to access the EGR tube nut from under the car. The optimal tool would be some kind of crows foot style flare nut wrench.
The sensor that connects to the EGR tube by two lengths of tubing is a differential pressure sensor for the EGR system.
Old August 1st, 2009, 05:21 PM   #30
The bolts that hold the fuel injector rail go into the lower intake manifold. It might be best the remove the lower intake manifold and have someone drill out the broken bolts.
Old August 1st, 2009, 05:46 PM   #31
2001 Mustang V6
14.89@93 mph
your a pretty niffty tool. Wish you were here earlier! I got everything situated besides the differential pressure sensor. What do i do with that now?
Old August 1st, 2009, 10:44 PM   #32
The differential pressure sensor has some wiring and two hoses connected to it. I would think it could be mounted anywhere the hoses and wiring will reach. If you are removing the EGR you won't need it.
Old August 2nd, 2009, 03:36 AM   #33
2001 Mustang V6
14.89@93 mph
then what do i do with the electrical?
Old August 2nd, 2009, 11:39 AM   #34
If you are deleting the EGR, I believe you need to have a tuner shut off the EGR codes.
Old August 5th, 2009, 03:44 AM   #35
2001 Mustang V6
14.89@93 mph
giving you guys an update. a 3" steeda hood is on the way along with a new lower intake manifold because i fucked up those bolts in mine real bad. But anyways about tha IAT where does that go? Like the front of the adaptor plate? How could i do that the fuel rail line is right there
Old August 5th, 2009, 05:26 AM   #36
Safi's Avatar
00 v6 & 99 Cobra
Like this
But you will need to get some extra fuel line hoses so that you can route the line around the IAT....Or you could do the same thing as in the picture, but just in the back of the adapter...its really up to you
Old August 5th, 2009, 09:10 AM   #37
2001 Mustang V6
14.89@93 mph
ok now from there. Where is it wired too???
Old August 5th, 2009, 01:52 PM   #38
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
plove71387 is on a distinguished road
The IAT Connects into the MAF wires go to VMP's site there is a diagram of how to wire in the MAF
edit : VMP Tuning - Buy Ford SCT & GM Custom Handheld Flash Tuners Performance Economy Towing: IAT / ACT Connector Harness
Old August 8th, 2009, 03:47 PM   #39
2001 Mustang V6
14.89@93 mph
does it matter which wire goes where????
Old August 8th, 2009, 03:57 PM   #40
Safi's Avatar
00 v6 & 99 Cobra
If you read the little passage on the site it explains everything for ya
To avoid potential problems this harness should be soldered. When hooking this harness up polarity does not matter.
On forced induction vehicles the air temp sensor must be mounted after the compressor or intercooler, so the computer can read the temp of the actual air going into the engine. This is very important for a safe tune.
Starting in 01/02 most Ford vehicles went to an air temp sensor that was built into the MAF sensor, if your MAF is mounted in suck-through before the blower you must relocate the IAT.
On 01-04 the gray wires pin 1 and pin 6 are for the IAT sensor, cut them and solder in the IAT sensor harness.
Threads Similar to: M112 Build
My M112-V6 Build plove71387 V6 Mustangs 148 November 1st, 2011 06:01 PM
M112 Ticket-Me-Yellow V6 Mustangs 66 June 21st, 2009 04:58 PM
m112 on a 2V ? SleeperStang88 99-04 12 June 9th, 2009 01:59 PM
m112 on v6 SleeperStang88 4V / SVT 3 April 29th, 2009 02:30 PM
m112 mmvi V6 Mustangs 34 March 5th, 2007 04:38 PM
