M112 Build - Page 3
Old August 9th, 2009, 01:40 PM   #41
Ticket-Me-Yellow's Avatar
2001 Mustang V6
14.89@93 mph
Ticket-Me-Yellow is on a distinguished road
Send a message via AIM to Ticket-Me-Yellow
what goes here??? its on the back right of the supercharger
Selling Mustang So Im
Selling All M112 Parts
Old August 9th, 2009, 10:40 PM   #42
2001 Mustang V6
14.89@93 mph
anyone?????
Old August 10th, 2009, 02:27 AM   #43
2001 Mustang V6
14.89@93 mph
still need help
Old August 10th, 2009, 02:58 PM   #44
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
plove71387 is on a distinguished road
hmmm .. you havent done much reasearch on doing this swap or so it seems .. you have to make a plate to put over that if im not mistaken but i maybe wrong.
Old August 10th, 2009, 09:47 PM   #45
2001 Mustang V6
14.89@93 mph
i did my research minus a few things. I ask a lot of questions mostly to double check. I would hate to screw something up. Next question is vaccum lines. The three lines in the back. Where do those go to?? Theres one big one and two medium ones. If you need a pic i can provide that.
Old August 10th, 2009, 10:06 PM   #46
328/419 @ 4000 rpms
Sure, Take a Picture and label them so i know exactly which three .. i think i remember what they all go to
Old August 11th, 2009, 01:06 AM   #47
2001 Mustang V6
14.89@93 mph
is the belt 4061182 the same belt everyone used? cause i tried it on mine and and that belt is lose as hell. i do have the lower profile adapter and UDP. Anyone use a different belt size???
Old August 11th, 2009, 01:46 AM   #48
328/419 @ 4000 rpms
Nope, I used a different one as well .. dont remember it. You can just take a peice of string/rope and run it around your belt setup and get a exact size that you need its alot more simpler then buying whatever belt the next person might tell you to try. Also, Try going over to Main Page - 3.8Wiki as theres quite a few people that have done it on there and 2/3 of them have write up that can quickly and easly answer most if not all of your questions. Good Luck and post some pictures.
Old August 12th, 2009, 08:20 PM   #49
2001 Mustang V6
14.89@93 mph
sorry i havent wrote much you guys but heres an update.
So i put the adapter plate on. Went to put the supercharger on and when i test fitted it it was about 1/2 to and inch off. So i had to pull everything back off drill all new holes and it worked.
The supercharger is now mounted. The intake is on. All i need to do is figure out these vaccum lines and get a new belt. Oh and make the bracket for the spark plugs. Here are some pics. and on my JLT intake i have two ports for a big and little vaccum line. If you guys need pics of that i can provide that too. But where do the vaccum lines on the back of the supercharger go? I delete the PCV and replaced them with breather vents
Old August 12th, 2009, 09:49 PM   #50
00BlueMustang's Avatar
2000 Mustang
00BlueMustang is a jewel in the rough00BlueMustang is a jewel in the rough00BlueMustang is a jewel in the rough
Looks good Yellow. What are you going to do about the hood?
Detailing Crew Member
North Carolina Modded Mustangs #5
Old August 12th, 2009, 10:00 PM   #51
2004 Mustang
3.9L Papke is on a distinguished road
I'm looking into this myself. Would you possibly write up a guide based on how you did it yellow?
Old August 12th, 2009, 10:05 PM   #52
2001 Mustang V6
14.89@93 mph
how i did what yellow the SVT?
Old August 12th, 2009, 10:06 PM   #53
2001 Mustang V6
14.89@93 mph
or how the whole project? and im going with the 3" cowl from steeda
Old August 12th, 2009, 10:16 PM   #54
2004 Mustang
Whole project, and total cost?
Old August 12th, 2009, 10:34 PM   #55
2001 Mustang V6
14.89@93 mph
i can possibly do that later but right now i gotta find out what those vaccum lines go to.
Old August 12th, 2009, 10:34 PM   #56
2001 Mustang V6
14.89@93 mph
and i believe parts were under 2000 with gauges and gauge pod
Old August 12th, 2009, 10:35 PM   #57
2001 Mustang V6
14.89@93 mph
not including hood
Old August 12th, 2009, 10:36 PM   #58
2001 Mustang V6
14.89@93 mph
also the vaccum lines for the boost bypass. where do those go
Old August 13th, 2009, 09:24 PM   #59
328/419 @ 4000 rpms
it cost me about 1700ish NOT including a hood/tune/tuner but i cut mine and then sold the kit.
I dont remember off the top of my head but I am looking thru my pictures of stuff now I just hope I have something to see were they went. Also, Nathan(MySteed) will help you with were all of those hoses go to I belive he is the one that told me were most of them went to.
Old August 13th, 2009, 09:56 PM   #60
328/419 @ 4000 rpms
Top Nipple gets routed to the inlet on the plenum(sp)
Bottom Nipple gets a cap/plug
M112 Back :
1 - If I remember correctly gets a cap/plug
2 - Vac for the Brakes
3 - This is for your Boost gauge and also I belive it links into your fuel pressure regulator thingy.
Hope this helps, also I WOULD check out Main Page - 3.8Wiki there are 4/5 Build threads that have m112's and you get all of these answers from there im sure as thats were I got most of my info.
Threads Similar to: M112 Build
My M112-V6 Build plove71387 V6 Mustangs 148 November 1st, 2011 06:01 PM
M112 Ticket-Me-Yellow V6 Mustangs 66 June 21st, 2009 04:58 PM
m112 on a 2V ? SleeperStang88 99-04 12 June 9th, 2009 01:59 PM
m112 on v6 SleeperStang88 4V / SVT 3 April 29th, 2009 02:30 PM
m112 mmvi V6 Mustangs 34 March 5th, 2007 04:38 PM
