#61 |
muneris pro ego
cant wait to see this thing completed man. good work so far
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
#62 |
2001 Mustang V6 Coupe
where did you get the supercharger from?
#63 |
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
You can find them fairly priced on SVTPerformance.com as many cobra owners upgrade to something better/bigger after a while.
#64 |
luckily i have a buddy with an 03 cobra. He's upgrading to a new KB setup, and said i could HAVE his stock one (eaton i believe?)
anyways... that probably wont be for another month or so
#65 |
328/419 @ 4000 rpms
#66 |
yea a lot more stuff. Im like 95 percent dont just need to do a little wiring and hook the vacuum lines up. Finally know how they go. Only crappy part is im outta town tomorrow and sunday but monday i believe will be the completion date
Selling Mustang So Im Selling All M112 Parts |
#67 |
328/419 @ 4000 rpms
I have that complete list if its needed. But im sure by now you have everything needed lol .. Good luck and hopefully my memory is correct and im not forgetting anything. Share some more pictures and BE careful and get a GOOD tune.
#68 |
I realize that...
#69 |
I have the whole split port swap kit shipping next week!
Then i can focus on the cobra parts, probably a focus svt fuel pump and a lightning MAF. Uhh t lok and gears, and a shift kit
![]() JAKE'S PIITB CREW MEMBER#4 |
#70 |
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
What are you using for your fuel setup? I'm just curious because I've heard of a few different ways that people do it.
#71 |
I have the 310 lph with the 42lb injectors.
#72 |
is the 310 lph from a lightning?
#73 |
2000 Mustang V6
need to run at track
![]() iTrader: 2 reviews
its from some of the 98-04 ford cars
_____________________________________________ ![]() 4.2 H/C/I with LT headers, sitting on 315s |
#74 |
you can get it from vmptuning.com
today i finally got to all of the vacuum liines. I hooked everything up and forgot about a crack i had in a coolent pipe. So when i started it up coolant went everywhere. but other then that she ran good for the 20 seconds she ran. Im waiting for the JB weld to dry so hopefully tomorrow she will start right up! Ill see if i can get a video goin
#75 |
ok so this morning i started her up but she is idling at 1900 rpms. Any reason why she should be doing that?
#76 |
Safud: MM's Resident Hadji
Go around and spray some carb cleaner to see if you have any vacuum leaks
#77 | |
328/419 @ 4000 rpms
+1 I would try this. The car will make a noise from the carb cleaner being sucked into the system from any leak. |
#78 |
im shooting three codes now.
P1285 P0722 P0720 whats the deal with these???
#79 | |
328/419 @ 4000 rpms
These two are something with your Trans and im not sure what to do or even to check with them. P0722 - Output Speed Sensor No Signal P0720 - Output Speed Sensor Circuit Malfunction Not sure if these even helps but hope so. |
#80 | ||
1998 Mustang 3.8
![]() ![]() iTrader: 6 reviews
Vote for Reps! ![]()
Threads Similar to: M112 Build
| My M112-V6 Build | plove71387 | V6 Mustangs | 148 | November 1st, 2011 06:01 PM |
| M112 | Ticket-Me-Yellow | V6 Mustangs | 66 | June 21st, 2009 04:58 PM |
| m112 on a 2V ? | SleeperStang88 | 99-04 | 12 | June 9th, 2009 01:59 PM |
| m112 on v6 | SleeperStang88 | 4V / SVT | 3 | April 29th, 2009 02:30 PM |
| m112 | mmvi | V6 Mustangs | 34 | March 5th, 2007 04:38 PM |
