#81 | |
1998 Mustang 3.8
![]() ![]() iTrader: 6 reviews
No one?
Vote for Reps! ![]()
#82 | |
Safud: MM's Resident Hadji
#83 | |
1998 Mustang 3.8
Mysteed's adapter plate, so it should be good. Thanks much.
#84 |
You doing the split port swap? I knew there had to be a reason you was selling your m90 kit lol
#85 | |
1998 Mustang 3.8
![]() I have no idea what you are talking about.....I don't even know what this...."Split port swap" you speak of is.
#86 | |
#87 | |
1998 Mustang 3.8
...What?
#88 |
01 True Blue v6
to slow to matter
Question. . . . .Will the UDP increase the boast when compared to a stock crank pulley.
#89 | |
Most people doing the M112 swap use a 42% UDP on the crank to get 7-8psi |
#90 |
ok so now im finally back and ready to finish her. I took her out today and she is still idling high. I have no idea why i checked the vaccum lines but still nothin. i did notice that there was a little smoke coming out of the breather vents from the cylinder heads. Is this normal?
Heres the Codes im tripping P1285 P0720 P0722 P1401 P1409
Selling Mustang So Im Selling All M112 Parts |
#91 | |
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
Possible Cause: Low engine coolant level. Base engine concerns. Engine cooling system concerns. CHT sensor concern. P0720 Insuficient Input From the Output Shaft Speed Sensor Possible Cause: OSS sensor circuit short to GND. OSS sensor circuit short to PWR. OSS sensor circuit open. Damaged OSS sensor. Damaged PCM. P0722 No Signal From Output Shaft Speed Sensor Possible Cause: Damaged OSS connector. Damaged OSS sensor, or not installed properly. Harness intermittently shorted or open. Didn't you get rid of your EGR? P1401 DPFE EGR Cirucit High Voltage P1409 EGR Vacuum Regulator Solenoid Circuit Malfunction |
#92 | |
#93 |
2004 V6 & 2000 GT
That's what I was thinking.
#94 |
So i took it into a shop today cause i just didnt have time to screw with it and they found the leak. Its between the lower manifold and the plate. Long story short lil rousch gave me a bad adapor causing it to leak. There tryin to fix it but ill let you guys know tomorrow
#95 | |
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
#96 |
it got fixed today. What they ended up doing was making a bigger gasket. came out perfect. Idles just where she needs to be. But bad news is when i went to go drive it and i heard something wrong with the tranny so i took it in and shes getting checked out right now
#97 |
When will you be getting her tuned?
#98 |
muneris pro ego
get it tuned and workin properly and itll be ftw!
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
#99 |
328/419 @ 4000 rpms
#100 |
yea deffinitly not. Once i get the tranny fixed it will be off to the dyno!
Threads Similar to: M112 Build
| My M112-V6 Build | plove71387 | V6 Mustangs | 148 | November 1st, 2011 06:01 PM |
| M112 | Ticket-Me-Yellow | V6 Mustangs | 66 | June 21st, 2009 04:58 PM |
| m112 on a 2V ? | SleeperStang88 | 99-04 | 12 | June 9th, 2009 01:59 PM |
| m112 on v6 | SleeperStang88 | 4V / SVT | 3 | April 29th, 2009 02:30 PM |
| m112 | mmvi | V6 Mustangs | 34 | March 5th, 2007 04:38 PM |
