MM's Official Lucifer
Center Console
How do you remove the 99-mid01 center console?
As some may recall I posted about my e-brake breaking though the floor pan somehow, and I need this console off to get to it. This also will help anyone wanting to switch from the early console to the late 01 and up for the repositioned cup holders and such. I will probably be doing that also, so anyone know someplace who sells them cheap?
^LMR doesn't seem to sell the entire console. However, since I have a short throw, my main issue isn't the cup holders, it's the fact that the lid is broken. LMR DOES sell the lids (for $110!!!!!) but I may just go that route. I still need the whole thing out though to fix my ebrake, so somebody tell me how!
pull off the shifter bezel and remove the bucket where the cig lighter is in the arm rest (just pull if remember) then remove the 4 exposed screws. now idk if u will be able to do this with it broken but pull the e brake all the way up and u should be able to lift it out.
ok, this is what I needed, I just didn't know the location of the screws and I wasn't about to just start pulling on it and break it. No matter that the lid is broken. What's the best way to get that bucket out? I can tell there's at least one clip on the driver's side of it, but it wasn't coming up easy, so I let it go. At least I know that's what I've got to do. Once it's out, reps to you Drew. Thank you sir.
#5 | |
MM's Database Error
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
1. Apply the parking brake as hard as you can.
2. If 4r70w place in 1. If manual you may have to remove shit knob. 3. Remove the floor console finish panel from around the shifter. 4. Disconnect the electrical connectors. 5. Open the floor console glove compartment and remove the floor console glove compartment bumpers. 6. To remove the floor console glove compartment storage bin. 6a. Remove the screws. 6b. Remove the floor console glove compartment storage bin. 7. Disconnect the floor console electrical connector. 8. To remove the floor console. 8a. Remove the screws. 8b. Pull upwards and slip over the park brake handle. Last edited by RFM 40th V6; August 3rd, 2009 at 07:04 PM. |
^AHHHHHH so you have to take those little rubber gromets (wtf is a gromet??!) out first! Thank you 40th that helps also, I'm gonna try this tonight if I don't end up at the Rays game.
2004 V6 & 2000 GT
No problem. I hope it works out for you. I know it was a bit confusing the first time i tried it.
2001 Mustang V6 Coupe
how can i get the coin holder out? does it pop out, or do you have to take the center console out and unscrew it?
2004 V6 & 2000 GT
The coin holder just pops out. You can use a small flathead screwdriver to pry it out. Be sure not to mar up the surrounding surface though.
Didn't get to it yet, but since I mentioned the Ray's game in my previous post I had to say that we beat tha Bosox! ahahaha walk off!
Reps to all, got it all done. As said, it's two screws under those rubber stoppers in the front end of the bin, then 2 screws underneath the bin, and two up front under the cd player.
So I fabbed up a little aluminum rectangle to act as a new nut under the floor pan to hold the front of the ebrake down. Just threaded it and it works great. Also reconnected the little sensor that throws the dash light on for the brake, thing has been disconnected for years, screw musta fallen out. So all works fine now, thanks again.
#13 | |
2004 V6 & 2000 GT
2000 Mustang v-6
by chance...did you take any pictures of the work you did? i have the same issue with my ebrake...bastard front bolt. Suggestion to all...dont yank your ebrake as hard as you can...you too can suffer the same fate...
2000 V-6 Coupe Mustang, 17 inch rims, custom hood, exhaust is done!! |
I do have a few, and can walk you through the whole process. I'm at work now, the pics are at home, so tonight I can post what I have. Basically once you get the whole console out it becomes clear what needs to be done. As said I just used a piece of aluminum to act as the "nut" for the front bolt under the floor pan. My dad turned the bolt in as I held the aluminum piece from underneath the car. We threaded the aluminum so it would hold.
2000 Mustang v-6
what gauge aluminum did you use? 1/4"? at first thought seems kinda weak metal to be threading into it. and yes, pics desired plz.
Ah I'm an asshole I forgot to post those up last night, I'll put them up this evening. Annnddd I believe it was 1/4" I'm not 100%, it was kinda just extra scrape laying around that I cut down to about an 1" x 1.5" (very rough estimate, never measured it). Then drilled a hole and threaded it, it got a few threads and fit snug onto the bolt.
![]() ![]() So here's the pics of what mine looked like broken. Unfortunately I didn't take any once I fixed it, musta been in a rush. Either way, that's the hole, and I already told you what I did to fix it, lemme know if you have any questions.
Threads Similar to: Center Console
| Center Console | goren813 | V6 Mustangs | 2 | March 21st, 2009 12:01 AM |
| 94-98 Center console in a 99-04? | Archy88 | Visual | 10 | December 24th, 2008 09:28 PM |
| Center console | 05bluestang | 2005 - 2010 | 20 | August 8th, 2008 05:21 PM |
| 90 GT center console. | INSTALLER020 | 5.0 Mustangs | 1 | June 8th, 2008 11:10 PM |
| No center console | jake1191 | 5.0 Mustangs | 2 | August 24th, 2007 10:08 PM |
