Discussing supercharger without cooling? in the V6 Mustangs Forum. is it possible to run a supercharger (low boost) without an intercooler, and would it ...
Old August 7th, 2009, 10:16 AM   #1
2004 3.9L V6
is it possible to run a supercharger (low boost) without an intercooler, and would it be safe and durable for daily driving?
American Muscle: CAI, 18in GT4 Wheels, Shorty Antenna, Front Chin Spoiler. Moto Blue UD Pulley / Water Pump Pulley, Steeda Tri-Ax Shifter, White Face Guage Overlays, and custom true dual exhaust with Flo-Pro V Force mufflers.
Old August 7th, 2009, 12:44 PM   #2
'00 3.8L
"In general we would not recommend intercoolers on supercharged engines with less than 8-9psi of boost, as the benefits will not be substantial. Essentially, run an intercooler when only when you running peak boost (i.e. any more boost would cause detonation) for the octane of fuel you use. Intercoolers work well in both warm and cool climates and work exceptionally well on marine applications because of the easy access to cold water."
-I just pulled that off a site from a quick google search. I suppose for low boost applications it isn't necessary or suggested. I do know that some chargers get hotter quicker then others, so it probably depends on your exact set up. If you want to push 10+ psi, then definitely.
"I don't like your parents because they birthed you." - FMR
Old August 7th, 2009, 01:10 PM   #3
Trick Tuners's Avatar
KB'd GT
An intercooler is always a good idea, even at low boost. You can run without one, but the IATs are sky high. some run meth, but i'm not a fan of it.
Issues with Methanol Injection - Trick Tuners Forums
Old August 7th, 2009, 06:17 PM   #4
2004 3.9L V6
thanks. does the m112 have a cooler that must be installed? I need some more info on locating those parts and some extra research.
Old August 7th, 2009, 07:12 PM   #5
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.4@93.6 aka way too slow
M112's do not have a cooler although I believe it is possible to mount the cobra one on there.
If you do though it's going to be sticking wayyyyyyyyy out of the hood.
04 V6-CAI|BBK Headers|Mac H-Pipe|Chip|B&M Shifter|T-Lok w/4.10s|FRPP Springs|Slotted & Drilled Rotors
00 GT-CAI|Accufab TB w/plenum | BBK H-pipe w/ Flowmaster 40's
Old September 15th, 2009, 06:56 PM   #6
a lot of ppl do it. what you would need is an alternate cooling source like methanol injection. which is a cheap and easy solution.
i have a full meth injection kit brand new kit for sale actually. PM me if anyone is interested
but they are working on a IC setup for the m12 just taking a while to come up with it
2003 3.8l Sonic Blue
2007 GSXR 750
For Sale:
Eaton M112 supercharger/plenum/ and 2 cobra TB's only $375!!! PM me!!
Old September 16th, 2009, 01:19 AM   #7
2004 V6 & 2000 GT
Hmm. If that's the case I think I'll hold off on my kit for a while.
Old September 16th, 2009, 12:33 PM   #8
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
+1
Vortech makes kit with out an intercooler on these cars. But keep in mind the higher the IATs the lower the power, the more stress and engine wear
m112 would have a heat changer, basically coolant that would run through the s/c to keep it cooler
Old September 16th, 2009, 12:38 PM   #9
00 V6 & 09 GT
ugh. ok reason why the tuner that posted and that many tuners in general dont like meth injection is for a few reasons.
Meth sure it works great when it works. but thats another thing that can go wrong, pump can go out, run low on juice. noozle not installed correctly blown fuse many small things.
now when one of those goes wrong and your tune depends on meth for higher boost, your motor will basically blow or be on the verge. when it blows or something goes wrong, the first person to get blamed will be the tuner. People will say why didnt you have a tune to counter act this blah blah blah.
thats why the most SIMPLE setups work the best and last the longest.
boost-a-pumps are the same just another thing that CAN go bad, fuse blow, boost a pump is basically an AMP, we all know how amps go bad.
keep in mind, BOTH meth and boost-a-pumps DO WORK and when they do they do a great job. WHEN it works
Old September 16th, 2009, 03:26 PM   #10
yeah but meth kits come with low level sensors and activation lights. if the pump fails you will know it. and if you stay out of boost your fine
2007 GSXR 750
For Sale:
Old September 16th, 2009, 03:29 PM   #11
00 V6 & 09 GT
This is true, but as I said and my experience with my tuner and talking with others they generally dont like it for those reasons.
Old September 20th, 2009, 08:16 PM   #12
yeah i jut think if you notice your activation light isnt comming on and your still getting into boost its your fault for being dumb and blowing your motor
2007 GSXR 750
For Sale:
Old September 20th, 2009, 08:21 PM   #13
v6 Mustang GOD
ESG-642T's Avatar
2k2 Mustang V6
So what if your at the 1000ft mark the quarter mile at 6k and the pump just goes out....
Old September 20th, 2009, 08:27 PM   #14
sue the meth company
2007 GSXR 750
For Sale:
Old September 20th, 2009, 10:38 PM   #15
v6 Mustang GOD
ESG-642T's Avatar
2k2 Mustang V6
Yeah that's not going to work....
Old September 21st, 2009, 02:08 PM   #16
KB'd GT
For sure. I'd bet that pumps fail more than baps.
haha, good luck! Sue ford for not building the engine tough enough while you are at it.
Old September 21st, 2009, 02:09 PM   #17
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
your supercharging something that isn't designed for boost, so i would do every little thing to help make it safe
2010 Goal: Join the 100 MPH club and be required to wear a helmet per NHRA rules, not saying I want to become a retard or something.
Old September 22nd, 2009, 08:15 PM   #18
00 V6 & 09 GT
this is true but at the same time while tuning the tuner will use the meth in the tune.
that in turn makes the motor rely on the meth kit.
btw folks I just had a buddy sunday blow the fuse on his boost a pump while racing in his cobra. he was lucky the car just shut off. but to think a .50cent part will cause a $4,000mistake....sucks.
the more things you add to car the more things can go wrong.
The most simple setups work best for a reason.
example-
local buddy has an SRT-4, direct port nitrous, 50trim, meth kit, dog box the WORKS and more.--28-30psi
this car is incredibly slow and has the worst turbo lag in the world and I could show you vidoes from youtube. the meth kit always runs low or fails or fouls his plugs. alcohol did the same.
another buddy, stock motor, 50trim just a tune on safe boost with good ole pump gas. 18psi
he blows the doors off the guy above. and made 100whp LESS.
Old September 25th, 2009, 10:12 AM   #19
Air Embolism Assassin
Cricket's Avatar
2004 Cobra #2260/3768
ahahahahah oh shit thats fuckin funny. Bet you scream rape if the breeze whistles by your taint too.
I don't exactly know if the v6 has an intake manifold to accomodate the intercooler of the m112, but like it was said you would probably either need to cut a hole in your hood or get a cowl.
MM Cobra Club #18
Team Tini Racing
Threads Similar to: supercharger without cooling?
cooling help jtyson8602 5.0 Mustangs 12 October 10th, 2008 11:31 AM
Cooling Down scramblr 2005 - 2009 14 September 9th, 2008 12:22 AM
Supercharger Cooling? SUHLeen 2005 - 2009 32 August 13th, 2008 09:41 PM
Cooling usafimj 2005 - 2009 4 June 25th, 2008 11:19 PM
cooling zhunter V6 Mustangs 2 January 25th, 2006 06:18 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
