flexplate access
Old August 12th, 2009, 10:36 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
flexplate access
Well the car is stuck in my moms garage so I have very limited room and tools. What's the easiest way I can get to the flexplate to put something in it so I can tighten the crank pulley bolt?
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old August 13th, 2009, 01:40 AM   #2
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
I wouldn't say there is really any easy way to do it.
Your best bet would be to pop out the inspection port plug in the bottom of the bell housing (the black rubber circle) and try to jam the flex plate that way. Be careful and make sure you can get whatever you use back out easily.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old August 13th, 2009, 09:58 AM   #3
Silverfoxbody's Avatar
Silverfoxbody is on a distinguished road
Send a message via MSN to Silverfoxbody Send a message via Yahoo to Silverfoxbody
what he said...jam up the flex with rags or something.
Old August 13th, 2009, 11:52 PM   #4
2000 V6
Hmm...it's a pain in the ass without tools or a floor jack. How dangerous would it be to drive to where I can acess an impact gun and other tools? The pulley is on, but a bit loose as it is not torqued down.
2000 V6 vert
Old August 14th, 2009, 02:05 AM   #5
2004 V6 & 2000 GT
That is a VERY BAD idea. The crank pulley is also your harmonic balancer and takes quite the beating.
You could damage your CKP sensor, the tone ring, lose your belt or even lose the pulley and be stranded in the process. It would be better to borrow someones or have them bring their stuff to you or tow your car someplace else to do it.
If you have your factory tire jack that will work well enough to get it onto some jack stands. Just make sure you set them on the subframe and not the control arms. Then it would be pretty easy to access the inspection port.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Threads Similar to: flexplate access
flexplate headache itschristorres8 5.0 Mustangs 8 August 3rd, 2009 12:15 AM
c4 flexplate spacer 707Stang The Clubhouse 4 February 5th, 2009 05:03 PM
C-4 Flexplate novamastr 5.0 Mustangs 10 January 31st, 2008 03:03 PM
flexplate kreil45 5.0 Mustangs 2 October 31st, 2007 01:46 PM
Flexplate Difference New88MustangOwner 5.0 Mustangs 2 November 10th, 2006 09:45 AM
