Discussing spacer in the V6 Mustangs Forum. hey guys i tried putting a throttle body spacer on my stang yesterday and the ...
Old February 6th, 2007, 11:40 AM   #1
mustang1072's Avatar
spacer
hey guys i tried putting a throttle body spacer on my stang yesterday and the engine will Rev really high for like 2 second and then die i worked on it the hole day and i cant figure it out... ne ideas
Originally Posted by Onemanzu
your moms a quicky... ha just playin ... but seriously
Originally Posted by Juggalo_X View Post
you bullshitting cock monger. .
Sold the stang
Old February 6th, 2007, 12:21 PM   #2
Moderator
Cricket's Avatar
8.876@80.013 1/8th
throttle body spacer is useless to you first of all, and make sure your maf is plugged in.
Originally Posted by 232stang
...and then cricket put in his $0.03 because hes above $0.02
Blue Mustang Society Member #001
click it
Old February 6th, 2007, 12:32 PM   #3
97TunedMustang's Avatar
sounds like you either forgot to plug back in a vaccum line or you accidentally knocked one loose. not to mention tb spacers are useless.
New block with forged internals running 16psi, tuned by Lasota Racing
Too many mods to list...
3.73's and Truetrac Finally Done!
Water-methanol injection?
Dyno Tune fo sho, Street tune FTL!
Old February 6th, 2007, 12:42 PM   #4
why are they useless to him? Just wondering. Thank you.
Old February 6th, 2007, 01:01 PM   #5
Resident MM Ricer
GreenFaleen's Avatar
2006 Scion tC
13.9@103/8.9@81
they serve no purpose they only widen the gap between the TB and the intake so if you get a bigger TB and the flap that opens hits the intake it will allow room for the TB to open fully. However they are obsolete now since TB's are engineered better than when the TB spacer was first invented.
Buy My Guitar and Amp
Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot tuning and install in process, Custom suspension, Doc. I 50% STS
Thanks To My Sponsors:
Strup Performance
Old February 6th, 2007, 01:37 PM   #6
i have the tb spacer so i may as well put it on... do u guys know how i can fix it?
Sold the stang
Old February 6th, 2007, 01:38 PM   #7
if it is a vacuum line what ever that is
Sold the stang
Old February 6th, 2007, 01:49 PM   #8
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
check your MAF first then make sure the spacer is tight and there is no air leaking in around it and the TB is bolted down well.
Strup Performance
Old February 6th, 2007, 01:57 PM   #9
well the tb is on and working great... the only thing im tryin to put on is the spacer... i have no idea what makes it act like this i have never heard of anything like this
Sold the stang
Old February 6th, 2007, 04:40 PM   #10
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
don't you need to take off the TB to put the spacer on?
Strup Performance
Old February 6th, 2007, 04:59 PM   #11
1995 BMW 325i
thats what im thinking
http://img.photobucket.com/albums/v3...5/cpc1copy.jpg
Originally Posted by Cesar2cool
lol i use my car for speed
Old February 6th, 2007, 05:16 PM   #12
you def need to take the tb off first...The only reason I have one was to drill it out for the bigger tb so I didnt have to do as much to the upper intake. Im getting one from the powerpack so it was just a temp fix.
Old February 6th, 2007, 06:00 PM   #13
2000 Mustang V6 n proud
13.1@107mph 2.1-60'
clean your IAC
390rwhp V6 mustang stock bottom end
Old February 6th, 2007, 06:36 PM   #14
of course i took off the tb b4 i put on the spacer... im not sure i know what the IAC is
Sold the stang
Old February 6th, 2007, 07:22 PM   #15
Moderator
turp's Avatar
1989 MUSTANG LX 5.0
16.17@86.21(bone stock on street tires)
Originally Posted by itschristorres8
clean your IAC
Cleaning your IAC (inlet air charge temp sensor) will do absolutely nothing. The only thing in an intake that you can "clean" for better air flow would be the MAF (mass air flow sensor) and I would not recommend doing that unless you have someone who knows what they are doing to show you how to do that, or cleaning the conical filter...
SUPPORT YOUR LOCAL HOOKERS....HUG A TOW TRUCK DRIVER!
Donate to lxhatch@gmail.com
Old February 6th, 2007, 07:53 PM   #16
mabe i should just sent id to a shop
Sold the stang
Old February 6th, 2007, 07:55 PM   #17
13.1@107mph 2.1-60'
didnt he say his car stall?
Old February 6th, 2007, 08:43 PM   #18
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
it really sounds like you have unmetered air coming in the engine and it isn't giving ti enough gas check all your connections real good.
Strup Performance
Old February 6th, 2007, 08:46 PM   #19
sorry guys i didnt explain this very well... i have the intake and tb on right now (runs great)... i recently got a tb spacer... and when i tried to put this on the only thing my car will do is rev @ 3k rpm for like 2 seconds and then die it does this every time i try to start it with the spacer on... keep in mind my car will run great with out the tb spacer... its kinda difficult 4 me to explain and sorry 4 that
Sold the stang
Old February 6th, 2007, 08:48 PM   #20
Moderator
turp's Avatar
1989 MUSTANG LX 5.0
Yes he did, and the only thing in the intake that would cause that is a maf sensor unplugged or bad/dirty. The IAC would only affect gas mileage and possibly cause detonation at high rpms...
Threads Similar to: spacer
G10 intake spacer Juggalo_X V6 Mustangs 27 June 24th, 2007 12:35 PM
intake spacer... ByPopularDemand V6 Mustangs 15 May 24th, 2007 09:42 AM
spacer droppedbass87 Visual 6 May 15th, 2007 02:28 PM
whats with the egr spacer nateo 5.0 Mustangs 7 April 9th, 2007 07:48 PM
Oil in EGR spacer??? Bill 5.0 Mustangs 4 February 25th, 2006 05:19 PM
