Weird Noises
Old February 7th, 2007, 12:47 PM   #1
addict is on a distinguished road
Send a message via Yahoo to addict
Weird Noises
So i was driving my mustang on the highway the other day and right when i hit 65 mph my engine started to make a loud hissing noise, so i pull off on the offramp and slowed down, and the noise went away untill i came to a stop, then it started again, but not as loud as on the highway. So i started driving to a parking lot to park the car and check out the engine, but i couldnt see what it was. Is there some common thing i need to get replaced, or should i take it to the dealership? Thanks for the help
Old February 7th, 2007, 01:03 PM   #2
mikethetigerrr's Avatar
mikethetigerrr is on a distinguished road
probally a vaccum hose or radiator hose. take a peak under the hood with the car running and try to feel for air leaking through hoses.
Old February 7th, 2007, 01:19 PM   #3
00stang is on a distinguished road
yeah best guess i got is wut he said
2000 Mustang V6
Old February 7th, 2007, 01:20 PM   #4
thanks, ill check that out once i get home tonight, sitting at school right now my class is boring.
Old February 7th, 2007, 01:22 PM   #5
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
DO NOT stick your hands around rad hoses when the engine is hot and running if you suspect a leak that is a sure way to get a third degree burn there bud. its most likely a vacuum leak is it on hard acceleration or when going up hill only? or when you turn the wheel? could be related to an egr system leak too if its only when you hit a cruzing speed. have you noticed any fuel millage changes or power loss? again i ask if its only when your on the gas pegal. and lastly is you check engine light on?
Old February 7th, 2007, 01:25 PM   #6
the noise only happens when im pressing on the gas, and the check engine light was on, but it is gone, (and has been for a two months) The guy i bought it from said the check engine light was from a chip that didnt effect performance, but yeah.
Old February 7th, 2007, 01:31 PM   #7
Juggalo_X's Avatar
14+@Slow
definitely get it checked by some one who doesn't say a check engine light is no big deal if it comes on SOMETHING IS malfunctioning. sounds to me like you have an erg vacuum system leak bud or a fuel system problem. get your fuel pressure checked your egr and vacuum lines checked and make sure your fuel filter is not plugged and crappy. could also be an intake leak when your throttle body is in an open position and u have leak you could hear the air rushing through a leak in the airbox system.
Old February 7th, 2007, 01:39 PM   #8
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
get that chip thing checked out too if it didn't do anything for performance it sounds like some kind of bypass chip also make sure your check engine light bulb isn't burnt out you'll fail emissions if it is.
NCMM #9
Old February 7th, 2007, 01:49 PM   #9
Juggalo_X's Avatar
14+@Slow
+1 that chip could easaly control the opening and closing of say your evap canister purge valve and that could cause a fuel system problem thus causing that sound on acceleration.
Old February 7th, 2007, 02:20 PM   #10
ha ok, now thats the kind of stuff i was thinking. My dad didnt think it was a big deal, but i knew something was up with it. Thanks guys, i'm gonna go get it checked out today.
Old February 7th, 2007, 02:20 PM   #11
MM's Resident Ricer
2006 Scion tC
13.001@113
good call. Also just turn your key to the on position and make sure the check engine light works.
NCMM #9
Old February 7th, 2007, 02:23 PM   #12
Juggalo_X's Avatar
14+@Slow
hope it isnt burnt out for his sake pulling the cluster sux ass
Old February 7th, 2007, 02:24 PM   #13
i know the bulb isnt out, the light comes when in in on position, but i didnt take it in for repairs or do anything myself, and the light went away my second week driving it. It made me worry, but i forgot about it untill this hissing sound started, now I'm scared to go drive :\
Old February 7th, 2007, 02:24 PM   #14
Old February 7th, 2007, 02:24 PM   #15
MM's Resident Ricer
2006 Scion tC
13.001@113
just don't drive to far you'll be fine.
NCMM #9
Old February 7th, 2007, 02:27 PM   #16
thanks, the dealership is right down the street from my school, so i wont have to go to far. By the way greenfaleen, sweet ride, was just looking at some pics of yours
Old February 7th, 2007, 02:28 PM   #17
MM's Resident Ricer
2006 Scion tC
13.001@113
Thanks
NCMM #9
Old February 8th, 2007, 06:15 PM   #18
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
all turn out well?
Threads Similar to: Weird Noises
grinding noises? blue03mach1 94-95 4 July 3rd, 2007 07:57 PM
transmision noises El_Cangri V6 Mustangs 22 April 6th, 2007 03:14 PM
Clicking Noises modded232 V6 Mustangs 11 April 6th, 2007 03:09 PM
Front end NOISES! 96mystic Modular Mustangs 4 February 8th, 2007 06:15 PM
Noises... Stan27 General Tech 20 June 22nd, 2006 04:06 AM
