cross shaft locking pin
Old August 21st, 2009, 08:02 PM   #1
2004 3.9L V6
risingerj is on a distinguished road
need some advice about motive gears i had some installed with a ford t lok. when it was all done the mechanic couldn't get the pin to go back in the diff. because the gear teeth are pertruding past the hole slightly. any ideas?
ford t lok w/ motive 4.10 gears.
American Muscle: CAI, 18in GT4 Wheels, Shorty Antenna, Front Chin Spoiler. Moto Blue UD Pulley / Water Pump Pulley, Steeda Tri-Ax Shifter, White Face Guage Overlays, and custom true dual exhaust with Flo-Pro V Force mufflers.
Old August 22nd, 2009, 05:51 AM   #2
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
So. . . . .A professional is having problems installing your gears and a t-lok, and is now asking you for help? . . . . . . .Sounds like you need a new mechanic.
Old August 22nd, 2009, 03:28 PM   #3
stephen has a spectacular aura aboutstephen has a spectacular aura about
Use a bolt with the same thread but smaller head. Just be sure it's the same grade of bolt and I think it's supposed to have lock tight on it.
Threads Similar to: cross shaft locking pin
Locking lugnuts... JBIGBOOTSY 5.0 Mustangs 30 June 14th, 2009 07:44 PM
Shafts move, new c-clip's, pin, shaft or all??? 1988 convertible 5.0 Mustangs 11 March 19th, 2009 04:24 AM
drive shaft shop one piece steel shaft ok for automatic tran mustang fanatic 2005 - 2010 8 September 24th, 2007 02:21 AM
Vapor Locking? blackhd 5.0 Mustangs 1 October 4th, 2006 04:27 PM
are 4 pin vs 5 pin relays the same OTreborO 5.0 Mustangs 3 August 21st, 2006 02:24 AM
