Need some oxygen sensor help.
Old August 22nd, 2009, 07:34 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
My car seems to like frying O2 sensors. I threw a code p0155 for the heater circuit (can't remember which bank.) The sensors and extensions are only 8 months old and this is the third or fourth set to crap out. Should I use a brand other than the oem sensors, or am I overlooking something else that could be causing them to fail so fast? Btw I do have LT headers.
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old August 22nd, 2009, 07:54 PM   #2
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to behold
iTrader: 8 reviews
maybe the tune is too rich or lean and its eating the o2s
Kenwood Head Unit $155
SCT Mass Air Flow Sensor $200
Old August 22nd, 2009, 08:29 PM   #3
2000 V6
Hmm could be. Never thought of that. Could the lean or rich condition mess with the heating circuit part of the sensor? The other thing is it's only one sensor?
2000 V6 vert
Old August 22nd, 2009, 08:38 PM   #4
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 8 reviews
im not even sure...but a pure guess would be like maybe its runnin sorta lean causing it to burn it up
Old August 22nd, 2009, 08:51 PM   #5
stephen has a spectacular aura aboutstephen has a spectacular aura about
You might check the heater circuit. Look up which pins connect to the heaters and compare the voltage on the left and right.
It could also result from an upstream air leak, but that should set a code.
Old August 23rd, 2009, 02:33 PM   #6
2000 V6
Do you think they would have a voltage tester at autozone? I'll have to try that. The only other code is it says it's running lean because of the o2 not working.
2000 V6 vert
Old August 23rd, 2009, 04:12 PM   #7
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
I'd look at the connector and harness that the 02 connects to. Make sure you don't have any exposed wires or burned up wiring insulation. It might be shorting them out.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old August 24th, 2009, 12:55 PM   #8
2000 V6
Alright. Bank 2 is the drivers side right?
2000 V6 vert
Old August 24th, 2009, 10:33 PM   #9
According to what I could find, bank one is the side with cylinder 1 or the right side. So bank 2 is the drivers side.
Old August 28th, 2009, 10:32 PM   #10
2000 V6
I looked and everything wire and connectionwise seems to be ok. Wierdest thing though...I decided to drive the car to work and the code cleared itself. On the way back the cel was off. Now I am really confused. Apparently something other than a faulty o2/wiring tripped the code
2000 V6 vert
Old August 29th, 2009, 06:51 PM   #11
2000 V6
Bump...any ideas anyone?
2000 V6 vert
Threads Similar to: Need some oxygen sensor help.
Need oxygen sensor help 86ttops 96-98 24 August 16th, 2009 09:43 PM
Oxygen Sensor bigredpaintbllr 5.0 Mustangs 10 July 19th, 2009 02:16 AM
Oxygen Sensor Locations saltydog_NM 5.0 Mustangs 2 June 6th, 2009 07:50 PM
Oxygen sensor question militant54 96-98 4 August 30th, 2008 05:56 PM
removing oxygen sensor 6banger96 V6 Mustangs 6 June 16th, 2008 10:45 PM
